电子发烧友论坛|
问候,我正在使用34901A / 34970A和一个自动程序来对LED颜色传感器的输出进行频率测量;
我发现它只有95%的时间有效。当它失败时它只返回'0',虽然有时候我收到了9.9E37,我把它解释为超出范围的指示。 当测量成功时,它在12KHz范围内,因此它肯定不会太快。 设置为10V范围,5 1 / 2D,FAST。 信号是5V,每106uS下降到0 V约12 uS。 我想知道如果因为LO仅占周期长度的12%左右,那么我可能是测量算法能力的“边缘”吗? 有一些过冲/下冲,但我在探头上放了一个3.3 nF的帽; 它清除了过冲/下冲但没有帮助测量。 请从信号的oscope捕获中查看附图。建议?谢谢! 以上来自于谷歌翻译 以下为原文 Greetings, I am using a 34901A/34970A with an automated program to make a frequency measurement of an output from a LED color sensor; I find that it works only about 95% of the time. When it fails it simply returns '0' although sometimes I have received 9.9E37 which I interpret as an out-of-range indication. When the measurement succeeds it is in the 12 KHz range so it certainly isn't too fast. The settings are 10V range, 5 1/2D, FAST. The signal is a 5V that drops to 0 V for about 12 uS every 106 uS. I am wondering if because the LO is only about 12% of the cycle length I may be 'on the edge' of the measurement algorithms capability? There is some over/undershoot but I put a 3.3 nF cap across the probes; it cleared up the over/undershoot but didn't help the measurement. Please see the attached image from an oscope capture of the signal. Advice? Thanks! 附件
1个回答
我无法重现这一点。
它对我来说很合适,具有9到12 KHz的0 - 5V,88%占空比方波,类似于客户所描述的。 我在第一次读数时得到零,但在此之后每次读数都得到了正确的频率。 我使用了默认设置:CONF:FREQ(@ 101)ROUT:SCAN(@ 101)(然后循环读取?命令)READ? 以上来自于谷歌翻译 以下为原文 I couldn’t reproduce this. It works fine for me with a 9 to 12 KHz 0 – 5V, 88% duty cycle square wave similar to what the customer described. I got zero on the first reading, but got the correct frequency for every reading after that. I used the default setup: CONF:FREQ (@101) ROUT:SCAN (@101) (and then looped on the read? command) READ? |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 09:35 , Processed in 0.664275 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1832
