好朋友几天后悔了,但你们中的一个可以告诉我如何启动PIC10f322汇编语言的PWM模块,我实现了一个草案,温度控制PWM,其中由于空间原因需要非常小的图片和理想我需要的想法是有一个50kHz的PWM与责任c。自行车,从0到100%不等,分辨率为5%,因为预见需要很多控制来执行,从已经非常感谢你希望你能帮助
以上来自于百度翻译 以下为原文 good friends days regreted but one of you could tell me how to start the PWM module of PIC10f322 assembly language I'm realisando a draft temperature control PWM in which for reasons of space nececito a very small pic and ideal for what I need to make the idea is to have a 50kHz PWM with the duty cycle that varies from 0 to 100% with a resolution of 5% since presicion need a lot of control to be performed from already thank you very much hope you can help |
1个回答
如果你不能正确地说英语,这很难,你在论坛上发表文章,人们会说英语。我从不同语言的经验中了解到这一点。你的要求很难被正确地理解。以下是我的建议:-如果你用母语发帖,我猜是西班牙语更好。-不管你是用英语(用谷歌翻译)还是用西班牙语发帖,都不要用一个很长的短语。使用短句,每一个有主语和谓语(名词和动词),每个人都很容易理解。甚至谷歌也会为你翻译得更好。不要使用单个长短语。-PIC10F322不适合用于温度测量,以防您想使用内部温度指示器。公差和误差太高。阅读下一步:HTTP://www. McCHIP.COM/FUMMS/M88 1560.ASPX
以上来自于百度翻译 以下为原文 It is very hard when you do not speak the language correctly, in this case English, and you post in a forum where people speak that language. I know it from experience with different other languages. Your request is hard to be understood properly. Here is my advice: - Maybe is better if you post your request in your native language, I guess Spanish. - No matter if you ask in English (translated with Google) or in Spanish, don’t use a single long phrase. Use short sentences, each with subject and predicate (noun and verb) very easy to be understood for everyone. Even Google will translate it better for you. Do not use a single long phrase. - PIC10F322 is not good for temperature measurements in case you want to use it internal temperature indicator. The tolerance and error are too high. Read next: http://www.microchip.com/forums/m881560.aspx |
只有小组成员才能发言,加入小组>>
5082 浏览 9 评论
1956 浏览 8 评论
1891 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3119 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2190 浏览 5 评论
637浏览 1评论
519浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
377浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
542浏览 0评论
443浏览 0评论
GMT+8, 2024-10-3 13:20 , Processed in 1.004379 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
