电子发烧友论坛|
这是迄今为止MPLABX.production.elf最讨厌的错误:无效的参数
以上来自于百度翻译 以下为原文 This is by far the MOST ANNOYING BUG in MPLABX .production.elf: Invalid argument |
10个回答
你能提供完整的错误信息和它的外观位置吗?哪个MPLABX和编译器有版本?能不能提供设备和项目类型(预构建的可加载/MaFIX文件)?
以上来自于百度翻译 以下为原文 Can you provide the complete error message and location of its appearance ? Which MPLABX and compiler with versions ? Couldn't hurt to provide device and project type (Prebuilt loadable/Makefile) ? |
嗨,我使用MPLABX V3.35与XC32编译器和和声V1.8。
以上来自于百度翻译 以下为原文 Hi, I'm using MPLABX v3.35 with XC32 compiler and Harmony v1.8. |
我不知道它是否在Windows10中工作。尝试它不会影响3.35的安装。它是更好的,但不是100%。假设如果您等到调试器上的繁忙灯熄灭,当您关闭调试器后再进行构建,就不会发生这种情况。
以上来自于百度翻译 以下为原文 I do not know if it works in windows 10 Try it is does not affect the 3.35 installation. It is better, but not 100% Supposedly if you wait until the Busy Light on the debugger goes out when you close the debugger before hitting build it will not happen. |
当某物/某人正在访问文件夹时,会发生这种情况,例如:在另一个时代,我有谷歌驱动器来备份我的工作。工作目录与驱动器同步,所以每当我编译驱动器正在同步文件时。这导致了在DIST文件夹和MPLAB上的剩余垃圾无法完成它的工作,因为它不能删除文件。
以上来自于百度翻译 以下为原文 this happens when something/somebody is accessing the folder for example: in another era i had google drive to keep backups of my work. working directory was synced with drive so whenever i was compiling drive was syncing the file. this led to leftover crap all over the dist folder and MPLAB unable to do its job because it couldn't delete files |
在这种情况下,另一个人是Mplabx。它保存了ELF文件锁定,因此其他线程不能删除它。
以上来自于百度翻译 以下为原文 In this case the someone else is Mplabx. It holds the elf file locked so other threads can not delete it. |
我认为这是固定在MPLAB X IDE V3.40中。发行说明(在3.40的10次修复和增强下)列出了MPLABX-27 90:“在某些情况下,调试(ELF)文件在构建/调试构建时被MPLAB X IDE锁定。当前的解决方法是单击性能监视器强制GC集合。“我以前在旧版本中多次遇到这个问题。自从升级到V3.40以来,我还没有经历过。
以上来自于百度翻译 以下为原文 I think this is fixed in MPLAB X IDE v3.40. The release notes (under 10 Repairs and Enhancements in 3.40) list MPLABX-2790 "On some occasions the debug (elf) file gets locked by MPLAB X IDE when doing a build / debug-build. The current workaround is to click the performance monitor to force a GC collection." I used to encounter that issue many times in older versions. I haven't experienced it since updating to v3.40. |
因为更新它只出现一次所以我会说它更好
以上来自于百度翻译 以下为原文 Since updating it only has appeared once so I'd say it's better |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
483 浏览 0 评论
5804 浏览 9 评论
2344 浏览 8 评论
2233 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3538 浏览 3 评论
1143浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1114浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
882浏览 1评论
485浏览 0评论
/9
GMT+8, 2025-12-8 08:47 , Processed in 1.018381 second(s), Total 61, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4035
