电子发烧友论坛|
我试图得到一台基本的个人电脑到MAX232连接,但完全受阻。我把它煮成最简单的状态:没有单片机,只有我的笔记本电脑和集成电路。我上面有5伏,所有必需的盖子(100nF)。我在插脚2和6之间得到+18V。我的PC电缆,就是这样,插脚2和3短了,我在超终端中得到了回环。当我把这些连接到IC上的终端(2->14和3->13),IC上的跳线12&11时,加电,在超终端中没有回波出现。我也试过其他的232集成电路(7/8和跳线10/9)。我试过不同的集成电路,在黑板上移动,我能想到的一切,没有乐趣。有人能提供一些东西吗?我肯定我错过了一些愚蠢的东西。谢谢。
以上来自于百度翻译 以下为原文 I am trying to get a basic PC to MAX232 connection and am being totally thwarted. I've boiled it down to its simplest state: No mcu, just my laptop and the IC. I have 5 V on it, all the requisite caps (100 nF). I get +18V between pins 2 and 6. My cable from the PC, with just that and pins 2 and 3 shorted I get the loopback in hyperterminal. When I connect these to terminals on the IC (2 -> 14 and 3 -> 13), jumper 12 & 11 on the IC, power up, no loopback echo appears in hyperterminal. I have also tried the other pairs of the 232 IC (7/8 and jumpering 10/9). I've tried different IC, moved around on the breadboard, everything I can think of, no joy. Can someone please offer something, I'm sure I am missing something stupidly obvious. Thanks. |
3个回答
假设你的电缆从PC是一个数据库5:你有没有电缆连接到MX23 2引脚15(GND)?用+5V加到MAX232管脚16,管脚15上的GND:将电缆连接到PC和MAX232,而不发送数据(空闲)。通过测量以下MAX232管脚处相对于MAX232管脚15:管脚13Pin 12Pin 11Pin 14Regards,Dave的直流电压来跟踪信号路径
以上来自于百度翻译 以下为原文 Assuming your cable from the PC is a DB9: Do you have Pin 5 of the cable connected to MAX232 Pin 15 (GND)? With +5V applied to the MAX232 Pin 16, GND on Pin 15: Connect the cable to the PC and to the MAX232 with no data being sent (Idle). Follow the signal path by measuring the DC voltages at the following MAX232 pins with respect to MAX232 Pin 15:
Regards, Dave |
此外,所有的电容器等都在最大程度上连接正确吗?我从来没有与他们有任何问题。
以上来自于百度翻译 以下为原文 Also, are all of the capacitors etc connected properly at MAX? I never had any issue with them |
戴夫,谢谢你说出了明显的显而易见的事实。这正是我所需要的。
以上来自于百度翻译 以下为原文 Dave, thanks for stating the indeed blindingly obvious (ground). It was exactly what I needed. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
492 浏览 0 评论
5806 浏览 9 评论
2346 浏览 8 评论
2234 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3541 浏览 3 评论
1146浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1116浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
883浏览 1评论
493浏览 0评论
/9
GMT+8, 2025-12-10 13:56 , Processed in 0.988418 second(s), Total 79, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1732
