嗨,我是这个软件的新手(3.45版)。我一直在尝试配置我的第一个项目,现在我又开始用同样的芯片在第二个基本项目上。当我构建新项目并将其设置为主项目(项目标题加粗)时,我单击MCC按钮开始配置。读取的mcc文件是前一个项目的旧文件。我在Linux Mint 17.3。如何重新开始?我应该期待一个全新的项目在一个新的和单独的文件夹,给我一个新的“空白”MCC文件?我应该期待MCC按钮图标链接到当前的主项目的MCC文件吗?如果没有MCC文件,它是否需要设置一个基本的空白文件?这是一个很基本的问题,RGDS,史提夫
以上来自于百度翻译 以下为原文 Hi, I'm new to this software (v3.45). I have been trying to configure my first project and now I start again with the same chip on a second basic project. When I have built my new project and I have set it as the main project (the title of the project is bolded) I clicked on the MCC button to start the configuration. The mcc file that was read was the old file from the previous project. I am on Linux Mint 17.3. How do I have a fresh start ? Should I expect a brand new project in a new and separate folder to be giving me a fresh 'blank' MCC file ?? Should I expect that the MCC button icon link to the mcc file for the current bolded main project ?? If there is no mcc file should it assume a basic and blank file needs to be setup ?? This is a pretty basic issue. Rgds, Steve |
4个回答
你好,史提夫,你提到你试图从以前的项目中加载一个旧的MCC文件。什么是MCC版本的配置文件,你试图加载到MCC V3.25?
以上来自于百度翻译 以下为原文 Hi Steve, You mentioned you are trying to load an old mcc file from a previous project. What's the MCC version of the configuration file you are trying to load into MCC v3.25? |
嗨,除了最新的3.45版本的IDE和MCC之外,我没有使用其他任何东西,也从未使用过较老版本的软件。我所做的只是做一个新的项目,然后尝试为这个项目“创建”一个新的MCC文件。当我点击MCC图标时,即使项目已经关闭,我也会得到以前的项目的MCC文件。RGDS,史提夫
以上来自于百度翻译 以下为原文 Hi, I'm not using anything other than the latest 3.45 version of the IDE and of MCC and have never used an older version of the software. All I'm doing is making a new project and then trying to 'create' a new mcc file for that project. When I click the MCC icon I get the previous project's mcc file even though that project has been closed. Rgds, Steve |
嘿,史提夫,我发现了导致这个的bug。无论何时创建使用与前一个MCC实例相同的设备的新项目,都会发生这种情况。我为不便向您道歉,并感谢您报告该问题。这个问题在IDMCCV3XX-4829下作为关键问题被记录在我们的系统中。EST解决方案是在创建新项目之前重新启动IDE。这将清除MCC的内存,防止旧配置进入新的配置。
以上来自于百度翻译 以下为原文 Hey Steve, I found the bug that causes this. It will happen anytime a new project is created that uses the same device as the previous MCC instance. I apologize for the inconvenience, and thank you for reporting the issue.This has been logged in our system as a critical issue under ID MCCV3XX-4829. Workaround: Until we can release a fix, the easiest workaround will be to restart the IDE prior to creating your new project. This will clear the memory of MCC and prevent the old configuration from bleeding into the new one. |
!谢谢你确认我没有失去理智:-另一个解决办法是使用下拉菜单。我认为这是在“运行”和“设置项目配置”下…或者“设置主项目”什么的。我现在不太记得了,干杯!向上和向上。
以上来自于百度翻译 以下为原文 ! Thank you for confirming I have not lost my mind :-) The other workaround is to use the drop down menu. I think it was under the 'run' and 'set project configuration' ... or 'set main project' or something. I can't quite remember now. Cheers! Onwards and upwards. |
只有小组成员才能发言,加入小组>>
4899 浏览 9 评论
1863 浏览 8 评论
1808 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3006 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2092 浏览 5 评论
499浏览 1评论
357浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
407浏览 0评论
297浏览 0评论
1053浏览 0评论
GMT+8, 2024-6-26 10:53 , Processed in 1.227151 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
