您好,当我在PIC32MZ EF SK上执行Flash_read_dma_mode程序示例时,它工作正常。如果我插入适配器板(ac320006),那么程序就留在DRV_SQI_Flash_ID_Check函数中,等待DRV_SQI_RXTHR中断标志。程序从不离开以下循环:而(PLIB_SQI_Inter.FlagGet(DRV_SQI_ID_0,DRV_SQI_RXTHR)==false);在适配器板上没有跳线。有人知道发生了什么?
以上来自于百度翻译 以下为原文 Hello, when I execute Flash_read_dma_mode program example on PIC32MZ EF SK, it works fine. If I plug the adaptor board (ac320006), then program stay in DRV_SQI_Flash_ID_Check function and wait for DRV_SQI_RXTHR interrupt flag. Program never leave following loop : while (PLIB_SQI_InterruptFlagGet(DRV_SQI_ID_0, DRV_SQI_RXTHR) == false); I have no jumper on adaptor board. Somebody knows what happened ? |
1个回答
参见来自微芯片支持的响应:******微芯片评论开始****嗨,Julien,看来适配器在高频引起硬件不兼容,从而干扰SQI信号。解决这个问题的一种方法是通过从连接到SQI引脚的J1连接器中移除引脚来修改适配器板,以防您只希望将它们与PIC32MZ EF启动器工具包上的串行闪存一起使用,并且不打算将它们重新配置为通过适配器板。让我知道这个答案是否有用。谢谢您。最好的问候,克里斯蒂安***微芯片评论结束***
以上来自于百度翻译 以下为原文 See response from microchip support : **** Microchip Comments Begin **** Hi Julien, It appears that the adapter is causing a hardware incompatibility at high frequencies which disturbs the SQI signals. A workaround to this problem would be modifying the adapter board by removing the pins from the J1 connector which connect to the SQI pins, in case you only wish to use them with the serial flash memory on the PIC32MZ EF Starter Kit and don't plan on having them reconfigured to communicate via the adapter board. Let me know if this answer is helpful. Thank you. Best regards, Cristian **** Microchip Comments End ****** |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 19:29 , Processed in 0.670435 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1128
