嘿,我试图了解如何在我的pic24fj256gb110上使用spi,但是我在数据表中找不到SDIx SDOx SCKx和SC。第15章没有告诉我,是PDMx PMAx PMSCx吗?如果是这样的话,我将如何将它们映射为SDI、SDO、SCK?我要用哪一个针来做SCK?谢谢
以上来自于百度翻译 以下为原文 hey I'm trying to find out how to use spi on my pic24fj256gb110, but I cant find SDIx SDOx SCKx and SC on the datasheet. chapter 15 doesnt tell me, is it PDMx PMAx PMSCx? if so how would I go about mapping them to be sdi, sdo, sck? and which pin do I set to to be SCK? thanks |
8个回答
它们是可重新映射的:我最好的建议是您使用pps.h include文件及其宏——您可以在这个论坛上搜索它!
以上来自于百度翻译 以下为原文 They're remappable: my best advice is that you use pps.h include file and its macros - you can search about it on this forum! |
您希望读取数据表的第10.4部分以查找所需的信息。
以上来自于百度翻译 以下为原文 You'll want to read section 10.4 of your datasheet to find the information you're looking for. |
谢谢大家,只是一个问题,我可以在哪里下载PPS?因为我看了一下,我只发现了一个8位MCU的版本
以上来自于百度翻译 以下为原文 thanks guys, just one quick question where can I download pps? cause I took a look and I only found a version for 8 bit mcus |
我会上传我的,但这是不可能的…里面是XC16安装,你检查了吗?
以上来自于百度翻译 以下为原文 I would have uploaded mine, but it's not possible... It is inside XC16 install, did you check yours? |
对于16位微控制器,现在建议您使用代码配置器而不是旧的外围库(PLIB)。但是,你可以在这里下载传统的PLIB。打开下载选项卡,滚动到最底部。
以上来自于百度翻译 以下为原文 For 16-bit microcontrollers, it is now recommended that you use the Code Configurator rather than the old Peripheral Libraries (PLIB). However, you can download the legacy PLIB here. Open the downloads tab and scroll to the very bottom. |
我告诉我的电脑在XC16(V1.26)中搜索PPS,但是它不在那里。
以上来自于百度翻译 以下为原文 I told my computer to search for pps in xc16 (v1.26), but its not in there. |
这是因为XC16不再与周围的图书馆一起出现。你刚刚被告知如何下载它们。
以上来自于百度翻译 以下为原文 That is because XC16 does not come with the peripheral libraries any more. You've just been told how to download them. |
的确,(也从上面的评论)我认为它不是PLIB的一部分。
以上来自于百度翻译 以下为原文 Indeed Though (also from a comment above) I had thought it was not part of PLIB. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:18 , Processed in 0.864276 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1357
