电子发烧友论坛|
在MPLAB®X的主要工具栏窗口上没有项目-GT;仪表板?我错过什么了吗?
以上来自于百度翻译 以下为原文 There is no item on MPLAB® X's main tool bar Window->Dashboard? did I missed something? Attached Image(s) |
8个回答
我通过卸载重新安装MPLABX得到它。但现在,几周后它又消失了。真烦人。有什么想法可以在不卸载X的情况下恢复吗?
以上来自于百度翻译 以下为原文 I got it back by uninstalling an reinstalling MPLABX. But now, after a few weeks it disappeared again. It is very annoying. Any idea to get it back without uninstalling X? |
你可以尝试给它分配一个键盘快捷键。
以上来自于百度翻译 以下为原文 You could try to assign a keyboard shortcut to it. Tools > option > keymap |
在Tools>.>keymap下没有快捷方式“仪表板”。它是在旧版本3.45下的,这个版本在我的PC上仍然有效。我试着卸载和重新安装3.51(没有仪表板窗口、菜单、快捷方式的版本),但是这没有帮助。仍然没有仪表板:
以上来自于百度翻译 以下为原文 There is no "dashboard" the shortcut under Tools > option > keymap. It is under older version 3.45, a version that still works on my PC. I have try to uninstall and reinstall 3.51 (the version without the da***oard window, menu, shortcut) but that does not help. Still no da***oard :-( |
我不知道这里到底发生了什么,甚至不知道这是怎么可能的。但是,下次发生这种情况时,在卸载/重新安装之前,尝试删除用户和高速缓存目录(您可以在Help->.中找到这些目录的位置),我不知道这是否会有帮助,但是它经常修复MPLAB X的奇怪问题,并且比重新安装MP容易得多当然,当然,重新启动并不能解决这个问题吗?
以上来自于百度翻译 以下为原文 I have no idea what is going on here, or even how it would be possible. But, the next time this happens, before you uninstall/reinstall, try deleting your user and cache directories (you can find the location of these directories in Help->About) I don't know if this will help, but it often fixes strange issues with MPLAB X, and it's a lot easier than reinstalling MPLAB X. Also, just to be sure, a reboot does not fix the issue? |
嗨,是不是仪表板被最小化了?你可以试试:窗口&重置窗口吗?你能展示你整个屏幕的截图吗?请检查窗口:Help>About如果我记得很清楚,您可以清理这些目录,这清理了MPLAB XRegards的一些启动参数
以上来自于百度翻译 以下为原文 Hi, Could it be that the dashboard is minimized ? Can you please try : Window > Reset windows ? Can you show a screenshot of your complete screen ? Please check the window : Help > About If I remember well, you can clean up these directories and this cleans up some startup parameters of MPLAB X Regards |
Windows和GT;复位窗口没有帮助。但是我已经重新安装了3.51。这一次删除所有数据“并列3.51”,我认为另一个选项(“全部”,“3.51之前所有”)将破坏我的运行3.45安装。有一个对话框要求从旧安装导入设置。我否认了,现在仪表板又回来了。但是我在不同的安装上有一次这样的行为。我们的目标是使用MPLAX X而不重新安装。不幸的是,我得到了其他任务的钱,然后玩MPLABX,所以我必须推迟下次测试的时间。他暗示我可以在“帮助”“关于”中找到App和缓存数据的位置。再一次,非常感谢你的帮助。
以上来自于百度翻译 以下为原文 Window > Reset windows did not help. But I have again reinstalled 3.51. This time deleting all data "tied to 3.51" I think the other option ("all", "all before 3.51") will ruin my running 3.45 installation. There was a dialog asking to import settings from older installation. I have denied it and now the dashboard is back again. Ok so far. But I have had this behaviour more then one time on different installations. The goal is to work with MPLAB X without reinstalling. Unfortunately I got my money for other tasks then playing around with MPLABX, so I must postpone further workaround testing to the next time this happens. But thanks for the hint that I can find the locations of app and cache data in "help" "about". Again, thanks a lot for your help. |
更新:在周末之后重新启动MPLABX 4.15这个问题。删除缓存数据并不能解决这个问题。不幸的是,在删除4.15个“绑定到4.15”的所有数据之后,重新安装了它,这一次不起作用。你知道我能做什么让它再次工作吗?还是我得等4.16?
以上来自于百度翻译 以下为原文 Update: Got this problem again restarting MPLABX 4.15 after the weekend. Deleting the cache data does not solve the problem. Unfortunately reinstalling 4.15 after uninstalling it with deleting all data "tied to 4.15 " does not do the trick this time. Any idea what I can do to get it working again? Or do I have to wait for 4.16? |
删除[用户] AppDATaROMMMPLABIDIDDEVV4.15解决了我的问题。
以上来自于百度翻译 以下为原文 Deleting [USER]AppDataRoamingmplab_idedevv4.15 solved my problem. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 19:26 , Processed in 0.728208 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2338
