您好,我希望有人可以帮助我,我正在编写一个程序扫描434970交换机单元中34901板的所有通道但是两行给我错误-103我找不到问题,代码是下一个:开关
(事件){case EVENT_COMMIT:EscribePto(“SYST:CTYPE?100 n”); LeerPto(); SetCtrlVal(panelHandle,PANEL_REPLY,reply); ProcessDrawEvents(); SetCtrlAttribute(panelHandle,PANEL_REPLY,ATTR_VISIBLE,1); EscribePto( “CONFigure:VOLTage:DC 10,(@ 101:120)”); EscribePto(“SENSe:VOLTage:NPLC 1,(@ 101:120)”); //(这是第一行给出了-103错误)EscribePto(“ROUTe:SCAN(@ 101:120)”); //(这是给我-103错误的第二行)EscribePto(“ROUTe:CHANnel:DELay 0.25,(@ 101:120)”); EscribePto(“TRIGger:COUNt 2”); EscribePto(“TRIGger:SOURce tiMer“); EscribePto(”TRIGger:TIMer 2“); EscribePto(”FORMat:READing:TIME:TYPE RELative“); EscribePto(”FORMat:READing:TIME ON“); EscribePto(”FORMat:READing:CHANnel ON“ ); EscribePto(“* OPC?”); break;}返回0;我已经查看了编程手册,但我发现错误,请提前感谢。 以上来自于谷歌翻译 以下为原文 Hello, i hope somebody can help me, im writing a program scan all channels from a 34901 board in a 434970 switch unit but two lines give me the error -103 and i can´t find the problem, the code is the next: switch (event) { case EVENT_COMMIT: EscribePto ("SYST:CTYPE? 100n"); LeerPto(); SetCtrlVal (panelHandle, PANEL_REPLY, reply); ProcessDrawEvents (); SetCtrlAttribute (panelHandle, PANEL_REPLY, ATTR_VISIBLE, 1); EscribePto ("CONFigure:VOLTage:DC 10, (@101:120)"); EscribePto ("SENSe:VOLTage:NPLC 1, (@101:120)"); //(this is the first line thata gives me the -103 error) EscribePto ("ROUTe:SCAN (@101:120)"); //(this is the second line that gives me -103 error) EscribePto ("ROUTe:CHANnel:DELay 0.25, (@101:120)"); EscribePto ("TRIGger:COUNt 2"); EscribePto ("TRIGger:SOURce TIMer"); EscribePto ("TRIGger:TIMer 2"); EscribePto ("FORMat:READing:TIME:TYPE RELative"); EscribePto ("FORMat:READing:TIME ON"); EscribePto ("FORMat:READing:CHANnel ON"); EscribePto ("*OPC?"); break; } return 0; i've already review the programmation manual but i can´t find the error, thanks in advance. |
1个回答
我将下面列表中的每个命令剪切并粘贴到我的34970A的Agilent Connection Expert交互式IO窗口中,一次执行一个,并且没有错误。
我所能建议的是发送* RST和* CLS,然后再试一次。 以上来自于谷歌翻译 以下为原文 I cut and pasted each command from your list below into the Agilent Connection Expert Interactive IO window for my 34970A, executed them one at a time, and got no errors. All I can suggest is to send *RST and *CLS and then try it again. |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:33 , Processed in 0.654822 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4492
