嗨,我一直试图使用RA5引脚作为开关的输入。当我运行代码时,它的行为就好像开关已经被按下一样。在大量爆头之后,我发现RA5的WPUA5可能无法工作,因为当我在外部放置一个电阻时,一切正常。我可能遗漏了某些东西或者没有正确地编写代码。在这里编写一小部分代码;#define SWITCH RA5//这就是我如何初始化RA5 pinANSA5=0;TRISA5=1;WPUA5=1;//这是我的交换机代码(SWITCH==0){for(x=0;x<=200;x+)_.(1000);如果(SWITCH==0){some code}请帮助加尔德
以上来自于百度翻译 以下为原文 Hi, i have been trying to use the RA5 pin as input for a switch. When i run the code, it behaves like the switch is already pressed. after a lot of head bursting i figured out the WPUA5 of RA5 maybe is not working coz when i put a resistor externally everything works fine. i might be missing something or not writing the code properly. writing a fraction of code here; #define SWITCH RA5 //this is how i initialize the RA5 pin ANSA5 = 0; TRISA5 = 1; WPUA5 = 1; //this is my switch code if(SWITCH == 0) { for(x=0;x<=200;x++) _delay(1000); if(SWITCH==0) { some code } } please help Regards |
4个回答
哇,模拟器现在允许连接外部电阻器?伟大的行动,妇联!
以上来自于百度翻译 以下为原文 Wow, the simulator now allows connecting external resistors? Great move, MCHP! |
嗨,Thanks DarioG和姆贝德回答,问题解决了。这是集成电路本身的一个问题。PIC由于某种原因而变得有缺陷。当我换了一个新的,效果很好,但是很奇怪。在实际的集成电路中,除了特定引脚的上拉电阻器之外,其他工作都正常,从来没有出现过这种问题。是什么原因引起的?静态的?
以上来自于百度翻译 以下为原文 HI, Thanks DarioG and MBedder for the reply. The problem is solved. It was an issue with the IC itself. The PIC had become faulty for some reason. when i replaced it with a new one, it works fine. Its pretty strange though. Never had such kind of problem with the actual IC where everything else works fine but the pull up resistor of a particular pin. what could have caused it? static? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:38 , Processed in 0.637061 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1119
