大家好!有人有经验吗?USB SIE是否使用偶数端点缓冲区描述符,只要设置了比特,例如,如果偶数端点被武装并且SIE接收到SETUP令牌,UIR.TRNIF将被设置?如果我现在明白了,它是如何从那里继续下去的?在控制写传输的情况下,是否为数据DA1和奇数端点提供了偶数端点?提前感谢!
以上来自于百度翻译 以下为原文 Hello to everyone! Does anybody have experience with UCON.PPBRST? Does USB SIE use the even endpoint buffer descriptors as long as the bit is set, e.g. if even out endpoint is ARMed and SETUP token is received by SIE, UIR.TRNIF will be set? How does it continue from there, if I now clear UCON.PPBRST? Do I arm even out endpoint for DATA1 and odd out endpoint for DATA0 in case of Control Write Transfer? Thanks in advance! |
5个回答
当我使用乒乓缓冲时,我启用了在UBS.CONFIG.h中的选项,并信任MLA来处理细节;-读取数据表,在PPBRST中有一行:“PPBRST必须在固件中清除”(DS9632 Rev E,第167页,第一段)。我将解释这意味着只要设置了位,乒乓缓冲就被禁用,并且只使用偶数缓冲器。MLA在配置期间断言比特,然后一旦配置就关闭。例如,这是来自MLA UBS.Engult.C线1981~1997:HTH,D。
以上来自于百度翻译 以下为原文 When I use ping pong buffering, I enable the option in u***_config.h and trust the MLA to handle the details ;-) Reading the datasheet, there is a line in the PPBRST: "PPBRST must be cleared in firmware" (DS39632 rev E, page 167, first paragraph). I would interpret that to mean that as long as the bit is set, ping-pong buffering is disabled and would only use the even buffers. The MLA asserts the bit during configuration and then turns if off once configured. For example this is from the MLA u***_device.c lines 1981-1997: // Assert reset request to all of the Ping Pong buffer pointers USBPingPongBufferReset = 1; //Re-Initialize all ping pong software state bits to 0 (which corresponds to //the EVEN buffer being the next one that will be used), since we are also //doing a hardware ping pong pointer reset above. for(i = 0; i < (uint8_t)(USB_MAX_EP_NUMBER+1u); i++) { ep_data_in.Val = 0u; ep_data_out.Val = 0u; } //clear the alternate interface settings memset((void*)&USBAlternateInterface,0x00,USB_MAX_NUM_INT); //Stop trying to reset ping pong buffer pointers USBPingPongBufferReset = 0; HTH, D |
丹诺,谢谢你的回答!说PPBRST强制SIE在设定时甚至使用BD是正确的吗?如果被清除后,SIE会先使用偶数,然后使用奇数的BD吗?为什么它是如此混乱的USB?:)
以上来自于百度翻译 以下为原文 Danno, thanks for the answer! Would it be correct to say that PPBRST forces SIE to use even BD's when set? If cleared after being set, will SIE first use even and then odd BD's? Why is it such a mess with USB? :) |
“PPBRST迫使SIE在设定时甚至使用BD是否正确?”对。这就是我解释数据表的方式。“如果设置完毕,SIE会先使用偶数,然后使用奇数的BD吗?”也许,但你为什么在乎?USTAT寄存器,它告诉固件关于最后一个事务,包括PPBI位。PPBI是“乒乓BD指示器”,告诉你它使用了什么。
以上来自于百度翻译 以下为原文 "Would it be correct to say that PPBRST forces SIE to use even BD's when set?" Yes. That is the way I interpret the datasheet. "If cleared after being set, will SIE first use even and then odd BD's?" Probably, but why do you care? The USTAT register, which tells the firmware about the last transaction, includes the PPBI bit. PPBI is "Ping Pong BD indicator" and tells you which it used. |
丹诺,我会关心,因为我想知道如何武装端点,DATA0或DATA1。
以上来自于百度翻译 以下为原文 Danno, I would care because I want to know how to arm the endpoints, DATA0 or DATA1. |
我将启用这两个,让USB外围设备告诉我它使用了PPBI。
以上来自于百度翻译 以下为原文 I would enable both and let the USB peripheral tell me which one it used via PPBI. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 00:51 , Processed in 0.698096 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1275
