电子发烧友论坛扫一扫,分享给好友
嗨,我想将一些cadence board文件导入到ADS中,以便在较旧的设计上运行一些模拟。
可以这样做吗? 如果是这样,我可以在网上找到一个教程或一些文档,我可以在这上面观看/阅读吗? 很抱歉重新发布,但有人用我原来的帖子作为试验场,我不想让它过来看。 问候,迈克 以上来自于谷歌翻译 以下为原文 Hi, I want to import some cadence board files into ADS to run some simulations on an older design. Can this be done? If so is there a tutorial or some documentation on the web somewhere that I can watch/read on this? Sorry for the re-post but somebody used my original post as a testing ground and I did not want this to get over looked. Regards, Mike |
4个回答
wiriwerwerw 发表于 2019-5-24 15:03 谢谢埃德温! 问候,迈克 以上来自于谷歌翻译 以下为原文 Thank you Edwin! Regards, Mike |
嗨Edwin,我试图从知识共享中心检索文档,这两个链接不起作用:1。http://edocs.soco.agilent.com/display/ads2011/ADS+Design+Flow+Integration 2. http ://edocs.soco.agilent.com/display/eesofkcads/Allegro+ADFI+Tutorial+Presentation第一号告诉我,我没有足够的权限查看文档(限制),第二号说链接不存在? 我尝试了Firefox和IE的两个链接,所以我认为我已经消除了浏览器问题。 请告诉我从哪里可以离开? 问候,迈克 以上来自于谷歌翻译 以下为原文 Hi Edwin, I attempted to retrieve the documents from the knowledge sharing center and these two links do not work: 1. http://edocs.soco.agilent.com/display/ads2011/ADS+Design+Flow+Integration 2. http://edocs.soco.agilent.com/display/eesofkcads/Allegro+ADFI+Tutorial+Presentation Number one tells me I do not have sufficient access to view the document (restricted) and number two say's the link does not exist? I tried both links from Firefox and IE so I think I have eliminated the browser problem. Please let me know where I can go from here? Regards, Mike |
嗨Mike,两个链接都需要知识中心帐户才能访问。
文档(链接#1)也可以在ADS 2011安装中找到。 从ADS程序点击F1打开“帮助”窗口。 然后浏览到输入输出>设计转换> ADS设计流程集成。 对于链接#2,如果您没有帐户,请在此处注册知识中心帐户。 您可以在此处注册:https://edasupportweb.soco.agilent.com/portal/page?_pageid = 36,472848& _dad = portal& _schema = PORTAL谢谢,Edwin Yeung安捷伦EEsof技术支持 以上来自于谷歌翻译 以下为原文 Hi Mike, Both links require a Knowledge center account to access. The documentation (link # 1) can also be found in an ADS 2011 installation. From the ADS program hit F1 to open the Help window. Then browse to Input-Output>Design Translation>ADS Design Flow Integration. For link #2 please register for a Knowledge center account here if you do not have an account. You can register here: https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,472848&_dad=portal&_schema=PORTAL Thanks, Edwin Yeung Agilent EEsof technical support |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:26 , Processed in 0.654339 second(s), Total 80, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3568
