电子发烧友论坛|
您好,在crt0.S中,我应该放置//以下代码片段在“C”启动代码//的开头,以查找来自睡眠的唤醒是否是由于WDtif(RCON&0x18)//WDT导致来自睡眠的唤醒{asm volatile(“eret”);//根据数据从中断返回}当我醒来的时候,我的WDT超时?善待本
以上来自于百度翻译 以下为原文 Hi All where in the crt0.S should I put // The following code fragment is at the beginning of the ‘C’ start-up code // to find whether the wake from Sleep is due to the WDT if ( RCON & 0x18 ) // The WDT caused a wake from Sleep { asm volatile( “eret” ); // return from interrupt } as per the datasheet when I wake up from sleep when my WDT timeout? Kind regards Ben |
1个回答
我认为,在文档中,省电模式只是让您知道如何处理看门狗超时NMI。如果有NMI,根据CRT0S,进程将被重定向到JNMIHAL处理程序,它已经通过XC32以弱版本实现。源是ATPIC32 LIBS/LIBPIC32/存根/默认NMI处理程序.S。所以基本上不需要做任何事情,除非您想处理WDT信息或清除RCON。如果您想拥有自己的版本的NMIIHANTHER,您可以只写一个C函数,比如“Valuy NmithHuffer-[Value]”来处理。S的信息,你也可以把原来的弱版本的nmil处理程序的ASM代码放在你的函数中。XC32 C/C++编译器的用户指南也有一些关于NMI和JNMIH-HANDLE的信息。
以上来自于百度翻译 以下为原文 I think in the document, Power-Saving Modes, just gives you an idea of how to handle a Watchdog Timeout NMI. If there is an NMI, according to crt0.S, the process will be redirected to the _nmi_handler, it's already implemented in a weak version by XC32. The source is at pic32-libs/libpic32/stubs/default-nmi-handler.S. So basically you don't need to do anything unless you want to process the WDT information or clear the RCON. If you want to have your own version of _nmi_handler, you can just write a C function like "void _nmi_handler(void)" to process the information, you may also put the original weak version _nmi_handler asm code within your function. the XC32 C/C++ Compiler User's Guide also has some information about NMI and _nmi_handler. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:20 , Processed in 1.129693 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1497
