电子发烧友论坛|
我正在使用GPIB向N6700B电源发送测量查询命令。
这种情况经常发生(每秒一次)。 发生这种情况时,前面板会随机刷新其电压和电流显示(显示“------”代替测量值,然后重新显示正确的值)。 除了降低测量频率外,有没有办法解决这个问题? 以上来自于谷歌翻译 以下为原文 I am using GPIB to send measurement query commands to the N6700B power supply. This is happening fairly often (every second). When this happens, the front panel randomly refreshes its voltage and current display (showing "------" in place of measurements, then re-displaying correct values). Is there any way to circumvent this issue, aside from decreasing the measurement frequency? |
1个回答
嗨,由于您通过GPIB快速进行测量,因此测量系统致力于提供这些测量。
您所看到的是在进行GPIB测量时前面板正在尝试刷新的实例。 这是正常的操作。 不幸的是,唯一的方法是降低测量频率。 如果您有任何其他问题或疑虑,请告诉我们。 马特 以上来自于谷歌翻译 以下为原文 Hi, Since you are taking measurements quickly over GPIB, the measurement system is engaged in providing those measurements. What you are seeing is an instance where the front panel is trying to refresh while you are taking a GPIB measurement. This is normal operation. Unfortunately, the only way around it would be to decrease your measurement frequency. Please let us know if you have any other questions or concerns. Matt |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
415浏览 0评论
/9
GMT+8, 2025-12-1 16:40 , Processed in 0.739531 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6080
