你好,
我有一个问题:如何用I2C实现CY8C27 43-24PXI中的SHT10湿度传感器?我读了很多数据表等,但我还是不知道怎么做。 谢谢大家的帮助。 以上来自于百度翻译 以下为原文 Hello , I have got question about : How can I implementation SHT10 humidity sensor in CY8C27443-24PXI using I2C ? I read a lot of datasheet etc. but I still do not know how. Thanks for all help. |
46个回答
所以我能看到数据线上的一些运行,但是时钟线没有显示任何东西。总传感器没有响应发出的命令。在我的项目中还有什么需要改变的吗?谢谢大家的帮助。
当做。 以上来自于百度翻译 以下为原文 So I was able to see some runs on the data line but clock line did not show anything. Total sensor did not respond to the command sent off. What else would need to change in my project? Thanks for all help. Regards. |
所以我必须使用Couter或者我应该怎么做?谢谢大家的帮助。
当做 以上来自于百度翻译 以下为原文 So i must use couter or what should I do ? Thanks for all help. Regards |
我改变错误=数据;到错误=DATAYDATAYADDR;并且我有0个错误。那么我的下一个问题是如何在PC机上发送CALC(8位测量湿度)并发送到集线器?我把PC桥(FTCP)放在计算机的USB中。将SHT-传感器放在射频扩展卡(FTRF)上。首先,我必须对RF扩展卡(FTRF)中的微处理机进行重新编程。当我这么做的时候。我从PC桥断开FTRF并连接到电源。什么模块或我应该用来发送湿度到PC,看到柏树感和控制仪表板的结果?谢谢大家的帮助。
以上来自于百度翻译 以下为原文 I change error=DATA; to error=Data_Data_ADDR; and i have got 0 errors. So my next problem is how calc ( 8 bit measure humidity ) and sent to hub in PC ?? I put PC Bridge (FTCP) in USB in computer. Put SHT sensor to RF Expansion Card (FTRF). First i must reprogram the microprocesor in RF Expansion Card (FTRF). When I do it. I disconnect FTRF from PC Bridge and connect to power. Whats moduls or what i should use to send this humidity to PC and see result in Cypress Sense and Control Dashboard ?? Thanks for all help. |
这是下载项目的下一个命题:
HTTP://www4/ZIPySyr.COM/V/8325666/FIL.HTML 如果有人可以下载这个项目并改进它,或者添加缺少的元素来正常工作?请帮助和感谢您提前每一个帮助。 以上来自于百度翻译 以下为原文 This is next proposition of project to download : http://www42.zippyshare.com/v/87325686/file.html if someone could download this project and to improve it or add missing elements to work properly? Please help and thank you in advance for each help. |
有人能帮我吗?谢谢大家的帮助。
当做。 以上来自于百度翻译 以下为原文 Can anybody help me ? Thanks for all help. Regards. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 09:04 , Processed in 0.650105 second(s), Total 55, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1501
