电子发烧友论坛|
早上好:很抱歉打扰你了,我有一个8340B选项H01 ....高于25.7GHz设置大于3dBm的功率水平显示一个不平等的消息...这是正常的,当功率水平设置为
较低的价值。 问题是,例如,当功率电平设置为更高(远高于26GHz左右的仪器功能)时,如+ 10dBm(使用****或通过键盘输入a值)... 未显示的消息显示(输出功率下降)并且在功率降低到-10dBm左右之前它不会消失,然后它可以上升到+ 3dBm左右。 似乎如果功率电平设置为高,则不平衡状态会锁定....这是8510C的一个问题,因为它将默认功率电平设置为10dBm并且高于25.7GHz它会失锁。 这是正常的,我在手册上找不到多少。 谢谢你编辑:martine1212于2012年8月15日12:08 AM编辑:martine1212于2012年8月15日12:15 AM 以上来自于谷歌翻译 以下为原文 Good morning: Sorry to bother you again, I have an 8340B options H01.... above 25.7GHz setting a power level greater than about 3dBm shows an unleveled message... which is normal and goes away when the power level is set to a lower value. The problem is when, for example, the power level is set to something higher (well above the capabilities of the instrument around 26GHz) like +10dBm (with the **** or by entering the a value with the keypad).... unleveled message shows up (output power goes way down) and it does not go away until the power is decreased to around -10dBm, then it can go up to around +3dBm. It seems that if the power level is set to high, the unleveled condition sort of locks up.... which is a problem with the 8510C since it set the default power level to 10dBm and above 25.7GHz it losses lock. Is this normal, I could not find much about it on the manuals. Thank you Edited by: martine1212 on Aug 15, 2012 12:08 AM Edited by: martine1212 on Aug 15, 2012 12:15 AM |
1个回答
嗨 - 我相信这种自动降低功率的操作是正常的 - 好像你要求8340产生过高的功率水平,你真的推动了一些非常昂贵且现在可能不可用的电源电路/放大器。
不幸的是,我们没有关于8340系列的所有信息。 希望论坛社区的某些人可以介入并协助。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - I believe this operation of automatically decreasing the power is normal - as if you ask the 8340 to generate too high a power level you are really pushing some very expensive and now probably unavailable power circuits/amplifiers. Unfortunately, we do not have all the information on the 8340 series. Hopefully someone from the Forum community can step in and assit. Regards - |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 05:56 , Processed in 0.577778 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
819
