电子发烧友论坛|
嗨,我是HP6812B的新手,我想根据DO-160D标准用来测试设备(Z类)的瞬态瞬态。
为此,GPIB控制的HP6812B具有LIST模式,看起来是一个完美的解决方案。 我可以从HP6812B本地键盘生成DC瞬变,但是在用LIST远程编程时我无法产生瞬态。 这个例子有什么问题? * RST OUTP:仅限COUP DCDC操作VOLT:OFFS 27.5; :VOLT 0初始27.5V DC OUTP ON列表COUN 2重复2次VOLT:MODE LIST LIST:VOLT:OFFS 27.5,13.7527.5V DC 10s和13.75V DC 10.5ms LIST:DWEL 10,0.0105 LIST:STEP AUTOList to paced 通过停留时间TRIG:SOUR BUSGPIB是trig的来源INItiate IMMediate:SEQuence1在触发器启动时生成触发器* TRG从BUS触发它 以上来自于谷歌翻译 以下为原文 Hi, I'm new to HP6812B which I want to use to generate DC transients to test equipment (category Z) according to DO-160D standard. For this purpose GPIB controlled HP6812B with LIST mode looks as a perfect solution. I could generate the DC transients from the HP6812B local keyboard, but I can't generate transients while programming remotely with LIST. What is wrong with this example? *RST OUTP:COUP DC DC operation only VOLT:OFFS 27.5; :VOLT 0 initial 27.5V DC OUTP ON LIST COUN 2 repeat 2 times VOLT:MODE LIST LIST:VOLT:OFFS 27.5,13.75 27.5V DC for 10s and 13.75V DC for 10.5ms LIST:DWEL 10, 0.0105 LIST:STEP AUTO List to be paced by Dwell time TRIG:SOUR BUS GPIB is source of trig INITiate IMMediate:SEQuence1 generates trigger when the trigger is initiated *TRG trigger it from BUS |
2个回答
在大多数情况下,当它由控制器控制时,您无法使用仪器前置键盘
以上来自于谷歌翻译 以下为原文 In most cases your not able to use the instruments front keyboard, when it's controlled by a controller |
嗨,你得到某种错误吗?
您的停留点数与您的电压点数不符。 这些需要匹配。 以上来自于谷歌翻译 以下为原文 Hi, Are you getting an error of some sort? Your number of dwell points does not match your number of voltage points. These need to match. |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 17:50 , Processed in 0.552419 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4402
