电子发烧友论坛|
您好我想象,通过VB宏或可能是CSV导入,我应该可以在史密斯圆图上为VSWR构建一个恒定的Z圆=一些值(例如2,2,4,3等对应
典型的回报损失)。 我不知道如何编程VB宏,我不知道这种方法是否相关。 请有人建议(a)这是可能的吗?(b)我该如何去做? 它不必作为限制线 - 只是一个视觉参考,所以我可以看到我的轨迹有多少被包裹起来(在例如VSWR = 2圈内)。 一个固定的圆(VSWR = 2)就可以了,一个可调整的圆(用户从三个固定值中选择)会更好。 感谢您对此事的任何帮助 以上来自于谷歌翻译 以下为原文 Hello I'm imagining that, via a VB macro or possibly a CSV import, it should be possible for me to construct a constant Z circle on the Smith chart for VSWR = some value (e.g. 2, 2.4, 3 etc. to correspond with typical return losses). I don't know how to program VB macros and I don't know if that approach would be pertinent. please couold someone suggest (a) is this possible and (b) how might I go about it? It doesn't have to function as a limit line - just a visual reference so I can see how much of my locus is wrapped up (inside the e.g. VSWR=2 circle). A fixed circle (VSWR=2) would be fine, an adjustable one (user selects from three fixed values for example) would be even nicer. Thanks for any help on this matter |
1个回答
只需创建一个MA格式的S1P文件,其中常量M和A在您的跨度范围内从0-360度变化。
导入S1P文件,你就可以了。 以上来自于谷歌翻译 以下为原文 Simply create an S1P file with in MA format with constant M and A varies from 0-360 degrees over your span of interset. Import the S1P file and there you have it. |
只有小组成员才能发言,加入小组>>
1854 浏览 0 评论
2749 浏览 1 评论
2651 浏览 1 评论
2471 浏览 5 评论
3475 浏览 3 评论
1854浏览 0评论
427浏览 0评论
/9
GMT+8, 2025-12-8 15:23 , Processed in 1.553028 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1250
