电子发烧友论坛|
显然,从第1.26节开始,谁知道Microchip为什么不可能阻止链接器产生IVT:HTTP://www. MicroChIP.COM/FUMMS/M917841.ASPXA从那时起,情况有了根本的改善?我有足够的麻烦到达我现在对我的工具链的理解,并且周围的工作方式似乎很复杂。这非常令人沮丧。
以上来自于百度翻译 以下为原文 Apparently, starting in v. 1.26, for who knows what reason Microchip made it impossible to stop the linker from generating the IVT: http://www.microchip.com/forums/m917841.aspx Has the situation improved at all since then? I had enough trouble to get to where I am now in my understanding of the tool chain, and the workaround presented seems convoluted. This is very frustrating. |
6个回答
看起来这是在V1.30中固定的——没有IVT链接器标志。它似乎只使用ELF格式。
以上来自于百度翻译 以下为原文 It looks like this was fixed in V1.30 with the --no-ivt linker flag. It only seems to work with ELF format. |
我这样做的目的是创建一个模块,其中每个中断向量都有空例程,或者陷阱和转储程序。这样,我就可以控制向量表的内容了。如果你错过了一个,编译器会把它指向一个重置例程,除非你在调试器中运行,否则它会被捕获到一个无用的例程。
以上来自于百度翻译 以下为原文 The way I got around this, was to create a module with EVERY SINGLE interrupt vector in it, with either null routines, or trap and dump routines. This way, I have control of the contents of the vector table. If you miss one, the compiler will point it to a reset routine, unless you are running in the debugger, when it will trap to a useless routine. |
是的,这是我试图避免的黑客攻击类型。幸运的是,他们已经解决了这个问题。没有IVT链接器标志正是我需要的。
以上来自于百度翻译 以下为原文 Yes, this is the type of hack I was trying to avoid. Luckily, they've fixed the issue. The --no-ivt linker flag was exactly what I needed. |
那不是黑客。这是防御性编程。在你的情况下,一个虚假的中断将重置你的设备。
以上来自于百度翻译 以下为原文 That is not a hack. That is defensive programming. In your case, a spurious interrupt is going to RESET your device. |
那不是黑客。这是防御性编程。在你的情况下,一个虚假的中断会重置你的设备。我说了什么让你知道我的代码是如何处理虚假中断的?
以上来自于百度翻译 以下为原文 That is not a hack. That is defensive programming. In your case, a spurious interrupt is going to RESET your device. What have I said that makes you think you know how my code handles a spurious interrupt? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:17 , Processed in 0.723765 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2146
