电子发烧友论坛|
嗨,我正在使用N8754A进行ATS编程。
我可以假设使用命令编程时N8754A的下降/上升时间如下所述吗? 下降时间(满载)150ms(下降时间+指令响应时间)上升时间(满载)130ms(上升时间+指令响应时间)下降时间(空载)800ms上升时间(空载)? 电压下降时间和上升时间小于150ms和130ms是否会在16V至0V之间变化,电流在下降时从200A变为0A,在0到16V之间电流从0到200A上升到上升时间? 我可以知道空载时的上升时间是多少? (未附在数据表中。)谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I'm using N8754A for ATS programming. Can I assume that the fall/rise time of N8754A when using command programming as stated below? Fall time (full load) 150ms (down-prog time+ command response time) Rise time (full load) 130ms (up-prog time+ command response time) Fall time (no load) 800ms Rise time (no load) ? Will the fall time and rise time less than 150ms and 130ms at voltage varies 16V to 0V with current varies from 200A to 0A for fall time and 0 to 16V with current varies from 0 to 200A for rise time? Can I know what is the rise time at no load? (It is not stated in the datasheet attached.) Thanks. 附件
2个回答
你好Thomas,没有指定没有加载的编程时间。
但是,您可以假设它小于满载所需的时间。 两者都是& 低于完整输出电压和电流偏移的编程时间将小于补充规范中公布的时间。 此致,PeterW 以上来自于谷歌翻译 以下为原文 Hello Thomas, Up programming time w/o a load is not specified. However, you can assume it to be less than the time required will a full load. Both up & down programming times, for less than full output voltage and current excursions, will be less than the times published in the Supplemental Specifications. Regards, PeterW |
谢谢(你的)信息! 以上来自于谷歌翻译 以下为原文 Thanks for the info! |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 06:47 , Processed in 0.622732 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4346
