电子发烧友论坛|
我试图使用matlab通过33210A波形发生器的arb波形输出一个Morelet小波。
我知道我无法使用具有任意波形的'Burst',但有什么方法可以让函数发生器允许我这样做吗? 我能够连接到设备,输入数据点并设置频率,Vpp和偏移。 我尝试使用暂停函数和波形的暂停=周期,但结果非常不一致。 想法? 以上来自于谷歌翻译 以下为原文 I am trying to output just one Morelet wavelet through a 33210A waveform generator's arb waveform using MATLAB. I know that I an unable to use 'Burst' with an arbitrary waveform, but is there someway to trick the function generator into allowing me to do so? I am able to connect to the device, input the data points and set the frequency, Vpp and offset. I have tried using the pause function with pause = period of the waveform, but the results are incredibly inconsistent. ideas? |
1个回答
这肯定是33210A的烦人限制。
33220A,33521A,33522A和33250A都允许您“突发”任意波形,但是在33210A中无法执行此操作。您可以在完成输出arb后更改功能以输出DC 0伏信号 ? 这可能不是最简单的时间,但它是一个选项。 如果你在你的arb中有额外的积分可以在实际波形之前以0伏引导,然后再次,那么你会花时间去做我上面提到的,或者可能发送OUTPUT OFF命令。不确定 如果其中任何一个适合你,但这些是我的头脑中的几个想法。 也许其他一些客户会回复其他人? 以上来自于谷歌翻译 以下为原文 That's definitely an annoying limitation of the 33210A. The 33220A, 33521A, 33522A, and 33250A all allow you to 'burst' an arbitrary waveform, but there is no way to do this in the 33210A. You could change the function to output a DC 0 volt signal after it's completed outputting the arb? This probably will not be the easiest thing to time perfectly but it's an option. If you've got extra points to play with in your arb you could lead with 0 volts before the actual waveform and then again afterward, this would buy you time to do what I mentioned above, or possibly sending the OUTPUT OFF command. Not sure if any of those will work for you, but those are a couple of ideas off the top of my head. Maybe some other customer's will respond with others? |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:45 , Processed in 0.559416 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3828
