我已经阅读了一些关于使用Spartan3的5v设备的信息,我仍然对它持有信心。
如果我理解正确的话,你可以用一个串联电阻来限制电流,钳位二极管可以工作,允许5v输入而不会烧断它。 我看到提到VCCTTL33输入或类似的东西。 我想,33的电压为3.3伏。 还有2.5,2.0和其他。 你怎么知道给定引脚是什么类型的信号? 换句话说,鉴于VCCOTTL33(或其所称的任何东西)的计算显示为300欧姆串联电阻,您如何判断哪个I / O引脚可以使用300欧姆电阻设置? 我期待制作一个小板,将Playstation2控制器连接到我的S3BOARD。 由于我有大约1000个1k电阻器,所以我只想使用它们。 这会减慢信号的速度,但它应该可以工作。 我很担心,我不想炸毁我的董事会! 谢谢, 凯文 以上来自于谷歌翻译 以下为原文 I have read a bunch of info on using 5v devices with Spartan3's and I am still leary about it. If I understand it correctly, you put in a series resistor to limit the current and the clamping diodes will work to allow 5v inputs without blowing it up. I saw mentions of VCCTTL33 inputs or something similar. The 33 makes 3.3 volts, I would think. There are also 2.5, 2.0 and others. How do you know what kind of a signal a given pin is? In other words, given the calculation for VCCOTTL33 (or whatever it was called) is showed as a 300 ohms series resistor, how can you tell which I/O pins will work with that 300 ohm resistor setup? I am looking to make a small board that will interface a Playstation2 controller up to my S3BOARD. Since I have about 1000 1k resistors, I was thnking of just using them. This would slow down the signals, but, it should work. I worry alot and I don't want to blow up my board! Thanks, Kevin |
5个回答
你可以忘记它,并在那里像74LCX125那样东西
http://www.fairchildsemi.com/ds/74%2F74LCX125.pdf Bobster 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 you could alwyas just forget it and stuff somthing like a 74LCX125 in there http://www.fairchildsemi.com/ds/74%2F74LCX125.pdf Bobster View solution in original post |
http://www.fairchildsemi.com/ds/74%2F74LCX125.pdf Bobster 以上来自于谷歌翻译 以下为原文 you could alwyas just forget it and stuff somthing like a 74LCX125 in there http://www.fairchildsemi.com/ds/74%2F74LCX125.pdf Bobster |
查看UG331.pdf。
在p。 351他们参考DS099.pdf,显示如何为不同的银行定义电压。 你希望你的Spartan3能持续多久? 依靠钳位二极管是长期可靠性的一个坏主意。 在p。 358讨论大信号Swign支持,他们建议使用两个电阻分压器(一个与您的源串联,另一个将Spartan3输入分流到地(1.7K系列,3.3K分流器,例如将5V转换为3.3V)。 只要您的上升和下降时间仍然可以接受,这比依靠钳位二极管更安全。 约翰 以上来自于谷歌翻译 以下为原文 Check out UG331.pdf. On p. 351 they referene DS099.pdf showing how the voltage can be defined for the different banks. How long do you want your Spartan3 to last? Relying on the clamping diodes is a bad idea for long term reliability. On p. 358 the discuss Large-Signal Swign support, and they recommend a two resistor voltage divider (one in series with your source, another shunting the Spartan3 input to ground (1.7K series, 3.3K shunt for example to translate 5V to 3.3V). As long as your rise and fall times are still acceptable that works. This is much safer than relying on the clamping diodes. John |
感谢你们两位回复。
我想我会分解并采取最安全的路线并使用低压缓冲器。 它会花费更多,但是,它很可能会让我免于烧毁我的电路板。 谢谢! 凯文 以上来自于谷歌翻译 以下为原文 Thanks to both of you for the replies. I think I am gonna break down and take the safest route and go with the low voltage buffers. It will cost more to do, but, it very well might save me from burning up my board. Thanks! Kevin |
这是最安全的方法。
我喜欢Fairchild NC7WZ17缓冲器。 我过去曾经使用它们,只要你能焊接它们,它们就能很好地工作。 约翰 以上来自于谷歌翻译 以下为原文 That is the safest approach. I'm fond of Fairchild NC7WZ17 buffers for this. I've used them in the past and as long as you can solder them they work great. John |
只有小组成员才能发言,加入小组>>
2184 浏览 7 评论
2621 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2095 浏览 9 评论
3159 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2213 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
456浏览 1评论
1544浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2189浏览 0评论
518浏览 0评论
1669浏览 0评论
GMT+8, 2024-5-22 09:18 , Processed in 1.334590 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
