- 【Arduino】66种传感器模块系列实验(80)
- 实验八十: OV7670摄像头模块30W采集拍照模组(替OV7725)
- 在github.com上的最新OV7670库文件之二
- OV7670.c
- #define F_CPU 16000000UL
- #include
- #include
- #include
- #include
- #include
- #include "ov7670.h"
- static const struct regval_list vga_ov7670[] PROGMEM = {
- {REG_HREF,0xF6}, // was B6
- {0x17,0x13}, // HSTART
- {0x18,0x01}, // HSTOP
- {0x19,0x02}, // VSTART
- {0x1a,0x7a}, // VSTOP
- {REG_VREF,0x0a}, // VREF
- {0xff, 0xff}, /* END MARKER */
- static const struct regval_list qvga_ov7670[] PROGMEM = {
- {REG_COM14, 0x19},
- {0x72, 0x11},
- {0x73, 0xf1},
- {REG_HSTART,0x16},
- {REG_HSTOP,0x04},
- {REG_HREF,0x24},
- {REG_VSTART,0x02},
- {REG_VSTOP,0x7a},
- {REG_VREF,0x0a},
- static const struct regval_list qqvga_ov7670[] PROGMEM = {
- {REG_COM14, 0x1a}, // divide by 4
- {0x72, 0x22}, // downsample by 4
- {0x73, 0xf2}, // divide by 4
- {REG_HSTOP,0x04},
- {REG_HREF,0xa4},
- {REG_VSTOP,0x7a},
- {REG_VREF,0x0a},
- static const struct regval_list yuv422_ov7670[] PROGMEM = {
- {REG_COM7, 0x0}, /* Selects YUV mode */
- {REG_RGB444, 0}, /* No RGB444 please */
- {REG_COM1, 0},
- {REG_COM15, COM15_R00FF},
- {REG_COM9, 0x6A}, /* 128x gain ceiling; 0x8 is reserved bit */
- {0x4f, 0x80}, /* "matrix coefficient 1" */
- {0x50, 0x80}, /* "matrix coefficient 2" */
- {0x51, 0}, /* vb */
- {0x52, 0x22}, /* "matrix coefficient 4" */
- {0x53, 0x5e}, /* "matrix coefficient 5" */
- {0x54, 0x80}, /* "matrix coefficient 6" */
- {REG_COM13,/*COM13_GAMMA|*/COM13_UVSAT},
- static const struct regval_list rgb565_ov7670[] PROGMEM = {
- {REG_COM7, COM7_RGB}, /* Selects RGB mode */
- {REG_COM1, 0x0},
- {REG_COM15, COM15_RGB565|COM15_R00FF},
- {0x4f, 0xb3}, /* "matrix coefficient 1" */
- {0x50, 0xb3}, /* "matrix coefficient 2" */
- {0x52, 0x3d}, /* "matrix coefficient 4" */
- {0x53, 0xa7}, /* "matrix coefficient 5" */
- {0x54, 0xe4}, /* "matrix coefficient 6" */
- {REG_COM13, /*COM13_GAMMA|*/COM13_UVSAT},
- static const struct regval_list bayerRGB_ov7670[] PROGMEM = {
- {REG_COM7, COM7_BAYER},
- {REG_COM13, 0x08}, /* No gamma, magic rsvd bit */
- {REG_COM16, 0x3d}, /* Edge enhancement, denoise */
- {REG_REG76, 0xe1}, /* Pix correction, magic rsvd */
- static const struct regval_list ov7670_default_regs[] PROGMEM = {//from the linux driver
- {REG_COM7, COM7_RESET},
- {REG_TSLB, 0x04}, /* OV */
- {REG_COM7, 0}, /* VGA */
- * Set the hardware window. These values from OV don't entirely
- * make sense - hstop is less than hstart. But they work...
- {REG_HSTART, 0x13}, {REG_HSTOP, 0x01},
- {REG_HREF, 0xb6}, {REG_VSTART, 0x02},
- {REG_VSTOP, 0x7a}, {REG_VREF, 0x0a},
- {REG_COM3, 0}, {REG_COM14, 0},
- /* Mystery scaling numbers */
- {0x70, 0x3a}, {0x71, 0x35},
- {0x72, 0x11}, {0x73, 0xf0},
- {0xa2,/* 0x02 changed to 1*/1},{REG_COM10, COM10_VS_NEG},
- /* Gamma curve values */
- {0x7a, 0x20}, {0x7b, 0x10},
- {0x7c, 0x1e}, {0x7d, 0x35},
- {0x7e, 0x5a}, {0x7f, 0x69},
- {0x80, 0x76}, {0x81, 0x80},
- {0x82, 0x88}, {0x83, 0x8f},
- {0x84, 0x96}, {0x85, 0xa3},
- {0x86, 0xaf}, {0x87, 0xc4},
- {0x88, 0xd7}, {0x89, 0xe8},
- /* AGC and AEC parameters. Note we start by disabling those features,
- then turn them only after tweaking the values. */
- {REG_COM8, COM8_FASTAEC | COM8_AECSTEP},
- {REG_GAIN, 0}, {REG_AECH, 0},
- {REG_COM4, 0x40}, /* magic reserved bit */
- {REG_COM9, 0x18}, /* 4x gain + magic rsvd bit */
- {REG_BD50MAX, 0x05}, {REG_BD60MAX, 0x07},
- {REG_AEW, 0x95}, {REG_AEB, 0x33},
- {REG_VPT, 0xe3}, {REG_HAECC1, 0x78},
- {REG_HAECC2, 0x68}, {0xa1, 0x03}, /* magic */
- {REG_HAECC3, 0xd8}, {REG_HAECC4, 0xd8},
- {REG_HAECC5, 0xf0}, {REG_HAECC6, 0x90},
- {REG_HAECC7, 0x94},
- {REG_COM8, COM8_FASTAEC|COM8_AECSTEP|COM8_AGC|COM8_AEC},
- {0x30,0},{0x31,0},//disable some delays
- /* Almost all of these are magic "reserved" values. */
- {REG_COM5, 0x61}, {REG_COM6, 0x4b},
- {0x16, 0x02}, {REG_MVFP, 0x07},
- {0x21, 0x02}, {0x22, 0x91},
- {0x29, 0x07}, {0x33, 0x0b},
- {0x35, 0x0b}, {0x37, 0x1d},
- {0x38, 0x71}, {0x39, 0x2a},
- {REG_COM12, 0x78}, {0x4d, 0x40},
- {0x4e, 0x20}, {REG_GFIX, 0},
- /*{0x6b, 0x4a},*/ {0x74,0x10},
- {0x8d, 0x4f}, {0x8e, 0},
- {0x8f, 0}, {0x90, 0},
- {0x91, 0}, {0x96, 0},
- {0x9a, 0}, {0xb0, 0x84},
- {0xb1, 0x0c}, {0xb2, 0x0e},
- {0xb3, 0x82}, {0xb8, 0x0a},
- /* More reserved magic, some of which tweaks white balance */
- {0x43, 0x0a}, {0x44, 0xf0},
- {0x45, 0x34}, {0x46, 0x58},
- {0x47, 0x28}, {0x48, 0x3a},
- {0x59, 0x88}, {0x5a, 0x88},
- {0x5b, 0x44}, {0x5c, 0x67},
- {0x5d, 0x49}, {0x5e, 0x0e},
- {0x6c, 0x0a}, {0x6d, 0x55},
- {0x6e, 0x11}, {0x6f, 0x9e}, /* it was 0x9F "9e for advance AWB" */
- {0x6a, 0x40}, {REG_BLUE, 0x40},
- {REG_RED, 0x60},
- {REG_COM8, COM8_FASTAEC|COM8_AECSTEP|COM8_AGC|COM8_AEC|COM8_AWB},
- /* Matrix coefficients */
- {0x4f, 0x80}, {0x50, 0x80},
- {0x51, 0}, {0x52, 0x22},
- {0x53, 0x5e}, {0x54, 0x80},
- {0x58, 0x9e},
- {REG_COM16, COM16_AWBGAIN}, {REG_EDGE, 0},
- {0x75, 0x05}, {REG_REG76, 0xe1},
- {0x4c, 0}, {0x77, 0x01},
- {REG_COM13, /*0xc3*/0x48}, {0x4b, 0x09},
- {0xc9, 0x60}, /*{REG_COM16, 0x38},*/
- {0x56, 0x40},
- {0x34, 0x11}, {REG_COM11, COM11_EXP|COM11_HZAUTO},
- {0xa4, 0x82/*Was 0x88*/}, {0x96, 0},
- {0x97, 0x30}, {0x98, 0x20},
- {0x99, 0x30}, {0x9a, 0x84},
- {0x9b, 0x29}, {0x9c, 0x03},
- {0x9d, 0x4c}, {0x9e, 0x3f},
- {0x78, 0x04},
- /* Extra-weird stuff. Some sort of multiplexor register */
- {0x79, 0x01}, {0xc8, 0xf0},
- {0x79, 0x0f}, {0xc8, 0x00},
- {0x79, 0x10}, {0xc8, 0x7e},
- {0x79, 0x0a}, {0xc8, 0x80},
- {0x79, 0x0b}, {0xc8, 0x01},
- {0x79, 0x0c}, {0xc8, 0x0f},
- {0x79, 0x0d}, {0xc8, 0x20},
- {0x79, 0x09}, {0xc8, 0x80},
- {0x79, 0x02}, {0xc8, 0xc0},
- {0x79, 0x03}, {0xc8, 0x40},
- {0x79, 0x05}, {0xc8, 0x30},
- {0x79, 0x26},
- static void errorLed(void){
- DDRB|=32;//make sure led is output
- while(1){//wait for reset
- PORTB^=32;// toggle led
- _delay_ms(100);
- static void twiStart(void){
- TWCR=_BV(TWINT)| _BV(TWSTA)| _BV(TWEN);//send start
- while(!(TWCR & (1<
- if((TWSR & 0xF8)!=TW_START)
- errorLed();
- static void twiWriteByte(uint8_t DATA,uint8_t type){
- TWDR = DATA;
- TWCR = _BV(TWINT) | _BV(TWEN); /* clear interrupt to start transmission */
- while (!(TWCR & (1<
- if ((TWSR & 0xF8) != type)
- errorLed();
- void wrReg(uint8_t reg,uint8_t dat){
- //send start condition
- twiStart();
- twiWriteByte(OV7670_I2C_ADDRESS<<1,TW_MT_SLA_ACK);
- twiWriteByte(reg,TW_MT_DATA_ACK);
- twiWriteByte(dat,TW_MT_DATA_ACK);
- TWCR = (1<
- _delay_ms(1);
- static uint8_t twiRd(uint8_t nack){
- if (nack){
- TWCR=_BV(TWINT) | _BV(TWEN);
- while ((TWCR & _BV(TWINT)) == 0); /* wait for transmission */
- if ((TWSR & 0xF8) != TW_MR_DATA_NACK)
- errorLed();
- }else{
- TWCR=_BV(TWINT) | _BV(TWEN) | _BV(TWEA);
- while ((TWCR & _BV(TWINT)) == 0) ; /* wait for transmission */
- if ((TWSR & 0xF8) != TW_MR_DATA_ACK)
- errorLed();
- return TWDR;
- uint8_t rdReg(uint8_t reg){
- uint8_t dat;
- twiStart();
- TWCR = (1<
- _delay_ms(1);
- twiStart();
- twiWriteByte((OV7670_I2C_ADDRESS<<1)|1,TW_MR_SLA_ACK);
- dat=twiRd(1);
- TWCR = (1<
- _delay_ms(1);
- return dat;
- static void wrSensorRegs8_8(const struct regval_list reglist[]){
- const struct regval_list *next = reglist;
- for(;;){
- uint8_t reg_addr = pgm_read_byte(&next->reg_num);
- uint8_t reg_val = pgm_read_byte(&next->value);
- if((reg_addr==255)&&(reg_val==255))
- break;
- wrReg(reg_addr, reg_val);
- next++;
- void setColorSpace(enum COLORSPACE color){
- switch(color){
- case YUV422:
- wrSensorRegs8_8(yuv422_ov7670);
- break;
- case RGB565:
- wrSensorRegs8_8(rgb565_ov7670);
- {uint8_t temp=rdReg(0x11);
- _delay_ms(1);
- wrReg(0x11,temp);}//according to the Linux kernel driver rgb565 PCLK needs rewriting
- break;
- case BAYER_RGB:
- wrSensorRegs8_8(bayerRGB_ov7670);
- break;
- void setRes(enum RESOLUTION res){
- switch(res){
- case VGA:
- wrReg(REG_COM3,0); // REG_COM3
- wrSensorRegs8_8(vga_ov7670);
- break;
- case QVGA:
- wrReg(REG_COM3,4); // REG_COM3 enable scaling
- wrSensorRegs8_8(qvga_ov7670);
- break;
- case QQVGA:
- wrSensorRegs8_8(qqvga_ov7670);
- break;
- void camInit(void){
- wrReg(0x12, 0x80);//Reset the camera.
- _delay_ms(100);
- wrSensorRegs8_8(ov7670_default_regs);
- wrReg(REG_COM10,32);//PCLK does not toggle on HBLANK.
复制代码
