电子发烧友论坛|
开发板可以正常nfs启动,但是做实验nfs下载uImage_nolcd时出现错误,如下所示,请大神指点一下问题在哪?
OpenJTAG> nfs 30000000 10.0.40.199:/work/nfs_root/fs_mini_mdev/uImage_nolcd dm9000 i/o: 0x20000000, id: 0x90000a46 DM9000: running in 16 bit mode MAC: 08:00:3e:26:0a:5b could not establish link File transfer via NFS from server 10.0.40.199; our IP address is 10.0.40.200 Filename '/work/nfs_root/fs_mini_mdev/uImage_nolcd'. Load address: 0x30000000 Loading: *** ERROR: Cannot mount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount done done done done done done done done done done done done done done done done OpenJTAG> sudo vi /etc/hosts 中增加了 10.0.40.200 /work/nfs_root/fs_mini_mdev/ 一样不行。 |
5个回答
我用的u-boot是2010的 2012的从哪下载呢?
我从网盘里找到一个U-Boot 2012.04.01 版本的,请问这个是最终版本么?因为我用的时候和以前的不太一样,按空格键不出现菜单了,只有如下所示的界面:
U-Boot 2012.04.01 (Dec 18 2012 - 04:44:13) CPUID: 32440001 FCLK: 400 MHz HCLK: 100 MHz PCLK: 50 MHz DRAM: 64 MiB WARNING: Caches not enabled Flash: 0 KB NAND: 256 MiB In: serial Out: serial Err: serial Net: dm9000 Hit any key to stop autoboot: 0 SMDK2410 # |
用了这个版本的U-Boot去nfs下载还是不行,一样有下面的问题:
U-Boot 2012.04.01 (Dec 18 2012 - 04:44:13) CPUID: 32440001 FCLK: 400 MHz HCLK: 100 MHz PCLK: 50 MHz DRAM: 64 MiB WARNING: Caches not enabled Flash: 0 KB NAND: 256 MiB In: serial Out: serial Err: serial Net: dm9000 Hit any key to stop autoboot: 0 SMDK2410 # ping 10.0.40.199 ERROR: resetting DM9000 -> not responding dm9000 i/o: 0x20000000, id: 0x90000a46 DM9000: running in 16 bit mode MAC: 08:00:3e:26:0a:5b could not establish link Using dm9000 device host 10.0.40.199 is alive SMDK2410 # nfs 30000000 10.0.40.199:/work/nfs_root/fs_mini_mdev/uImage_nots ERROR: resetting DM9000 -> not responding dm9000 i/o: 0x20000000, id: 0x90000a46 DM9000: running in 16 bit mode MAC: 08:00:3e:26:0a:5b could not establish link Using dm9000 device File transfer via NFS from server 10.0.40.199; our IP address is 10.0.40.200 Filename '/work/nfs_root/fs_mini_mdev/uImage_nots'. Load address: 0x30000000 Loading: T *** ERROR: Cannot mount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount *** ERROR: Cannot umount done done done done done done done done done done done done done done done done SMDK2410 # |
ERROR: Cannot mount
这问题可能来自两方面: 1.UBOOT 2.服务器 我们先确定服务器没问题,你在服务器上MOUNT 自己试试,比如执行这样的命令(这只是个例子,IP、目录需要自己修改): sudo mount -t nfs -o nolock,vers=2 10.0.40.199:/work/nfs_root/fs_mini_mdev /mnt 如果成功,就表示服务器没问题。 对于UBOOT问题,换上我们的u-boot-1.1.6 试试 |
只有小组成员才能发言,加入小组>>
296个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2467 浏览 6 评论
2201 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4828 浏览 1 评论
/9
GMT+8, 2025-12-3 16:40 , Processed in 0.956020 second(s), Total 86, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1418
