电子发烧友论坛|
我在演示板上运行WiFi G演示和声固件有问题。它编译好,但在初始化时停止调试模式。我在3.25V的ICD3上为演示板供电。问题似乎是:TCPIpHyMultMeal.C中的.TCPIPSTACKISRUNSTATE():WHEMACSTATT和LT;0和CaltScPIPpStaskBurnNETWORD(),这应该是方兴未艾的,对吧?其他人看到了解决的办法吗?我使用的是:-和谐框架:V1.10,和声配置器:V1.0.10,MPLABX IDE:V3.51,调试器:ICD 3与ICSP适配器,Java:1.80Y91;64位,系统:Mac OS X105.5运行在X8664上
以上来自于百度翻译 以下为原文 I have problems running the WiFi G Demo HARMony firmware on a Demo board. It compiles fine but stops in Debug mode during initialisation. I am powering the demo board from the ICD3 at 3.25v. Problem seems to be in: _TCPIPStackIsRunState() in tcpip_manager.c, where macStat < 0 and calls TCPIP_STACK_BringNetDown(). This should run out-of-the-box, right? Anyone else seen a solution to this? I am using:- Harmony Framework: v1.10, Harmony Configurator: v1.0.10.0, MPLAB X IDE: v3.51, Debugger: ICD 3 with ICSP adapter, Java: 1.8.0_91; 64-Bit, System: Mac OS X 10.9.5 running on x86_64 |
4个回答
谢谢。我已经成功地建立和运行了V310C固件更新,但没有LED开启。我正在用XC32 V1.33编译(V1.42没有编译)。有什么想法吗?
以上来自于百度翻译 以下为原文 Thanks. I have built and run the v310C firmware update successfully but no LEDs turn on. I am compiling with XC32 v1.33 (v1.42 does not compile). Any ideas? |
更正:似乎我需要为外部板供电(DOH)。我已经设立了板是由现在安装的ICD3.FW更新供电。谢谢你的帮助!
以上来自于百度翻译 以下为原文 Correction: seems I need to power the board externally (doh). I had the board set up to be powered by the ICD3. FW update now installed.. Thanks for your help.! |
XC32 V1.42是协调的正确编译器V1.10i能够在V1.08或V1.09中获得与Hyg论坛中的编译器错误相关的挖掘工作。我假设您在MHC上有正确的版本。您只做了一个构建和程序,没有改变什么?
以上来自于百度翻译 以下为原文 XC32 V1.42 is the correct compiler for Harmony V1.10 I was able to get mine work in V1.08 or V1.09 Deal with the Compiler errors in the Harmony Forum. I assume you have the correct Version on MHC. And that you only did a Build and program and did not change anything? |
是的,只有建造和程序,没有变化会在更进一步的和谐中再次出现。
以上来自于百度翻译 以下为原文 yes, build and program only, no changes will chase up further in Harmony forum Thanks again.! |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 19:47 , Processed in 0.635928 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2245
