电子发烧友论坛|
我使用PIC16F1788和PICtiT3,我想使用引脚RB6&RB7作为一个USAT连接(我不能使用备用引脚RC6和RC7用于USAT连接,因为它们被4x4键盘使用)。我的问题是如果我把RS232转换器的电路与ICSP隔离开来。如果是这样的话,我该怎么做呢?
以上来自于百度翻译 以下为原文 I'm using the PIC16F1789 with the PICkit3 and I want to use the pins RB6 & RB7 for a USART connection (I cannot use the alternate pins RC6 and RC7 for the USART connection because they are used by a 4x4 keypad). My question is if I have to isolate the circuit of RS232 converter from the ICSP and if so, how can I do that? |
1个回答
很清楚,你提出的电阻是什么,但是我有一个“愚蠢”的问题。用一个电阻在引脚RB6/RB7和电路的其余部分之间,当PIC在正常工作时,这个电阻不会影响这个电路的运行,因为它限制了电流从电子别针?很明显,如果引脚连接到需要一个电阻器来限制电流的装置,比如LED、BJT等,那么这个电阻器不会引起任何问题。但是其他设备,比如RS232或者别的什么呢?
以上来自于百度翻译 以下为原文 It's clear what you proposed with the resistors, but I have a, let's say "stupid", question. Using a resistor between the pins RB6/RB7 and the rest of the circuit, when the PIC is in normal operation, won't this resistor affects the operation of this circuit, since it limits the current flow from the pins? It's obvious that if the pin is connected with a device that needs a resistor to limit the current flow, like a LED, a BJT, etc., then this resistor won't cause any problems. But what about other devices, like the RS232 or something else? |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
478 浏览 0 评论
5799 浏览 9 评论
2338 浏览 8 评论
2229 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3534 浏览 3 评论
1133浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1109浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
876浏览 1评论
480浏览 0评论
/9
GMT+8, 2025-12-4 13:25 , Processed in 1.050115 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3110
