我正在尝试使用MyFr24WG WiFi模块。我已经配置了(使用和谐配置器)模块来使用WPA-2安全性的基础设施网络。不清楚是否应该调用一些API来触发与接入点的连接。我确信SPI通信正在工作,因为DRVSTATUSSIGET返回正确的ROM版本,但是无法连接到我的Ap感谢。
以上来自于百度翻译 以下为原文 I'm trying to use the MRF24WG WiFi module. I have configured (using HARMony Configurator) the module to use Infrastructure networking with WPA-2 security. It is not clear if some APIs should be called to trigger connection with access point. I'm sure that the SPI communication is working because DRVSTATUS_GET returns the correct ROM version, but cannot manage to connect to my AP Thanks |
3个回答
请确保您在StysLogConf.h中指定正确的AP SSID。Wi-Fi模块将扫描并连接到同一SSID的AP。通常与AP的连接困难是由于拼错AP SSID或设置错误的安全模式和密码。请仔细核对一下。请注意,MRF24WG不支持N-AP。请在AP中选择混合模式。
以上来自于百度翻译 以下为原文 Make sure your specify the correct AP SSID in system_config.h. The Wi-Fi module will scan and connect to AP with same SSID. Usually difficulty connect with AP is due to misspell AP SSID or set the wrong security mode and passphrase. Please double check. Also please notice MRF24WG doesn't support N-only AP. Please select mixed mode in AP. |
请仔细检查SSID是否在StimeSyf.g和AP中是相同的。也请注意,MRF24WG不支持11N仅AP。请确保您的AP设置为混合模式或11BG或11G。如果设置已经正确,请将您的SysLyFig .h设置设置为Wi-Fi,如果可能的话,WiRESHARK跟踪。
以上来自于百度翻译 以下为原文 Please double check if SSID is same in system_config.h and the AP. Also please notice MRF24WG doesn't support 11n-only AP. Please make sure your AP is set to mixed mode or 11bg or 11g. If the settings are already correct, please post your system_config.h settings for Wi-Fi and if possible Wireshark trace. |
经过多次测试,我可以说MRF24WG工作正常,不需要任何呼叫连接。它直接使用和声配置器中指定的连接参数。集成天线的性能似乎非常差(我的接入点离模块大约3M/10英尺),连接外部天线提高了很多的连接稳定性。
以上来自于百度翻译 以下为原文 After many tests I can say that the MRF24WG works correctly and does not need any call to connect. It directly uses the connection parameters specified in Harmony configurator. The integrated antenna seem to have a very poor performance (my access point is about 3m / 10ft away from the module), connecting an external antenna improved a lot the connection stability. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1123浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 01:04 , Processed in 0.523272 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
947
