您好,我想设计一个低功耗系统,可以使用5个以上的无线振动传感器://store.ncd.io/product/iot-long-range-wireless-vibration-and-temperature-sensor/
将数据发送到调制解调器所有传感器都单独使用2AA电池,但我想将设备与外部12v AC连接到DC电源适配器,该适配器将使用分压器为外部传感器供电。 我能够为每个传感器获得所需的电压,但要正确供电。 我需要一些专家建议来制作一个易于使用所有传感器的原型。 任何建议都会非常有帮助。 以上来自于谷歌翻译 以下为原文 Hello, I want to design a low power consumption system which will work with more than 5 wireless vibration sensors https://store.ncd.io/product/iot-long-range-wireless-vibration-and-temperature-sensor/ which can send the data to modem all sensors are using 2AA batteries individually, but I want to connect the device with external 12v AC to DC power adaptor which will provide power to sensors externally using a Voltage divider. I am able to get the required voltage for every sensor but to make the proper supply. I need some expert advice to make a prototype which will easy to use with all the sensors. any suggestion will be very helpful. |
1个回答
你的想法真的非常可观。
我已经访问了您在文章中提到的页面。 您也可以从东芝支持中获得一些有趣的想法。 这种电源管理系统与无线传感器非常兼容。 以上来自于谷歌翻译 以下为原文 your idea is really very appreciable. I have visited the page that you have mentioned here in the article. You also may get some interesting ideas from Toshiba Support. this power management system is very compatible with the wireless sensor. |
只有小组成员才能发言,加入小组>>
2413 浏览 7 评论
2820 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3371 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2456 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1030浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
576浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
434浏览 1评论
1998浏览 0评论
721浏览 0评论
GMT+8, 2024-12-18 17:17 , Processed in 1.386343 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
