电子发烧友论坛|
嗨,我刚刚有一个PIC32 MX好奇开发板,我正在尝试上传一个项目。我只是用MPLAB和声做了一个空白的项目,并试图用SKOB调试器将它上传到电路板上。项目建立正确,但随后陷入了发射阶段。加载条被卡住,调试器控制台说“启动”,但什么都没有发生。是否有一个驱动程序需要我下载,以便使用SKOB调试器?我在Mac跑车埃尔卡皮坦,万一有问题,谢谢!
以上来自于百度翻译 以下为原文 Hi, I just got a PIC32MX Curiousity Development Board, and I am trying to upload a project. I just made a blank project with MPLAB HARMony and tried to upload it to the board using the SKOB debugger. The project builds correctly, but then gets stuck in the launching stage. Loading bar is stuck at full, debugger console says "launching" but nothing ever happens. Is there a driver I need to download in order to use the SKOB debugger? I am on a Mac running El Capitan, in case that matters. Thanks! |
19个回答
所以什么版本都没有?和声和MHC的版本匹配吗?董事会有多大年纪?
以上来自于百度翻译 以下为原文 So no Versions on anything? Does the Version of Harmony and MHC match? How old is the Board? |
MPLAB IDE V3.51 MPLAB®和声集成软件框架V1.10不确定如何在我的好奇心板上找到版本,没有修订号或任何东西,但它说它是在2016年10月20日被检查的。这周我刚收到。
以上来自于百度翻译 以下为原文 MPLAB X IDE v3.51 MPLAB® Harmony Integrated Software Framework v1.10 Not sure how to find version on my Curiosity Board, there is no revision number or anything, but it says it was inspected October 20, 2016. I literally just got it this week. |
刚刚尝试调试我的另一台计算机,它运行Windows 10。这成功地擦除设备内存并开始编程,之后我得到以下错误信息:目标设备没有准备好调试。请检查配置位设置并在继续之前对设备进行编程。这种故障最常见的原因是振荡器和/或PGC/PGD设置。我如何解决这个问题?
以上来自于百度翻译 以下为原文 Just tried debugging on my other computer, which runs Windows 10. This succeeds in erasing device memory and begins programming after which I get the following error message: The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings. How do I fix this? |
空白项目,完全空白?你至少需要配置振荡器来调试运行。大多数PIC32芯片也有多对调试引脚,你必须配置它来使用好奇板使用的对。(我没有一个,所以我不知道答案。)
以上来自于百度翻译 以下为原文 Blank project, as in totally blank? You need to at least have configured the oscillator for debugging to run. Most PIC32 chips also have multiple pairs of debuug pins, and you have to configure it to use the pair the Curiosity board uses. (I don't have one, so I don't know the answer.) |
振荡器和所有配置字需要设置为有效值。和谐是否有一个测试项目为您的董事会?一些旧的调试板芯片旧的工作更长,你的是新的。
以上来自于百度翻译 以下为原文 The oscillator and all the configuration words need to be set to valid values. Does Harmony have a test project for your board? Some old boards with old debugger chip longer work, yours is new. |
我只是使用MPLAB和谐来创建一个PIC32 MX470F512H项目,而不需要改变任何东西。我现在在和谐配置器的设备配置选项卡中查看。我看到DEVCFG1拥有所有的振荡器选项,但我不知道如何正确配置好奇板。我只是尝试建立一个简单的示例项目,一些闪烁的LED,让我熟悉这个板上的编程。看起来应该比这更简单吗?有人能推荐一个引导/示范项目吗?
以上来自于百度翻译 以下为原文 I just used MPLAB Harmony to create a project for PIC32MX470F512H without changing anything. I am now looking in the device configuration tab of the Harmony Configurator. I see that DEVCFG1 has all the oscillator options, but I am unsure how to configure them correctly for the Curiousity Board. I am just trying to set up a simple example project, something to blink a few of the LEDs and allow me to get familiar with programming on this board. It seems like it should be simpler than this? Can anyone recommend a guide/example project? |
我已经尝试下载包含在板上的示例项目,但是这些都是用于USB通信的,这对于我的应用来说既不必要,也有点复杂。此外,在我打开它们时,它们就有了构建/配置错误:警告:配置“PicxMxOSUBSK22IN yDyn”用“XC32”构建,但不指示工具链Drimuly.Ifn:配置“PicxMxUsBSK22In yDyn”将在“应用程序/Microchip /XC32/V1.42/BI”中用工具链“XC32”构建。n:“警告:配置”PIC32 MXXUSBSK2IN ItyDyn指文件“/”埃米特/下载/ MSDYBASIC/固件/SRC/StulySCOFIG/PIC32 MXYSUBSK22IN yDyn/Frase/Stfs/FS/NVMyDISKYMIX H,它不存在于磁盘中。制作过程可能无法正确建立等。
以上来自于百度翻译 以下为原文 I have tried downloading the example projects included for the board, but these are both for USB communication, which is both unnecessary for my application and somewhat complicated. Additionally they have build/configuration errors as soon as I open them: warning: Configuration "pic32mx_u***_sk2_int_dyn" builds with "XC32", but indicates no toolchain directory. info: Configuration "pic32mx_u***_sk2_int_dyn" will build with toolchain "XC32" at "/Applications/microchip/xc32/v1.42/bin". warning: Configuration "pic32mx_u***_sk2_int_dyn" refers to file "/Users/Emmett/Downloads/msd_basic/firmware/src/system_config/pic32mx_u***_sk2_int_dyn/framework/system/fs/nvm_disk_images.h" which does not exist in the disk. The make process might not build correctly. etc... |
是否安装了编译器?XC32没有提供MPLABX,这是一个单独的安装。
以上来自于百度翻译 以下为原文 Do you have the compiler installed? XC32 is not supplied with MPLABX, it's a seperate install. |
您可以尝试一个示例应用程序来确保所有的工作。然后你需要看教程中的和声。如果您的应用程序不使用任何堆栈,您可以选择不使用和声。MPLABX将做出一组正确的配置。或者你可以复制一个和声项目。如果您的项目不需要MX的电源,您可以使用MM或PIC24。他们使用的MCC有点容易使用。
以上来自于百度翻译 以下为原文 You can try one of the sample apps to insure everything works. Then you would need to look at the tutorials for harmony. You have the option to not use harmony if your app is not using any of the stacks. MPLabX will make a set of correct configurations. Or you can copy from a harmony project. If you project does not need the power of an MX you can use an MM or a pic24. They use MCC which is a bit easier to use. |
是的,我确定要安装它。我也在Projts属性下选择了XC32(V1.42)在编译器工具链中。这个示例项目的问题似乎是它在项目目录SRC/StulySCOFIG下缺少PIC32 MXXUBSK22IN yDyn文件夹,但是当我查看目录中的项目文件夹时NT。知道发生了什么事吗?
以上来自于百度翻译 以下为原文 Yes I made sure to install that. I also went under project properties and selected XC32(v1.42) under compiler toolchains. The problem with the example project seems to be that it is missing the pic32mx_u***_sk2_int_dyn folder under the project directory src/system_config, but when I look in the project folder that directory is present. Any idea what is going on? |
此外,我正在寻找董事会支持包的好奇心,但它是从我的MPLAB和谐配置器缺席。我可以下载这个插件支持包吗?
以上来自于百度翻译 以下为原文 Also, I am looking for the board support package for the Curiosity but it is absent from my MPLAB Harmony Configurator. Can I download this board support package somewhere? |
和谐是一个整体。不支持添加组件。V2.02B有可能为好奇心板提供支持。
以上来自于百度翻译 以下为原文 Harmony is a monolith. Adding components is not supported. It is possible the V2.02b has support for the curiosity board. |
我会试试看。OnMuMe-从MPLAB OrthyYV202开始,它列出了MX470好奇心驱动程序作为beta版,这将是有意义的。我目前正在尝试安装2.02,但唯一的和谐插件我的版本MPLAB发现的是1.1版本。我尝试进入MPLAB的工具并卸载1.1插件,但是它只是在可用插件中再次出现,从来没有看到过2.02。有什么想法我能得到MPLAB看和谐2.2?
以上来自于百度翻译 以下为原文 I will try that. In Volume I - Getting Started with MPLAB Harmony_v202 it lists the MX470 Curiosity Driver as Beta so that would make sense. I am currently trying to install 2.02, but the only Harmony plug-in my version of MPLAB is finding is the 1.1 version. I tried going into tools in MPLAB and uninstalling the 1.1 plugin, but it just shows up again under available plug-ins, which never sees 2.02. Any idea how I could get MPLAB to see Harmony 2.2? |
我成功安装了MPLAB和谐V.2.02,这让我获得了MX470好奇心的电路板支持包。然而,当我生成一个项目时,仍然会从调试器中获得相同的错误:编程/验证完成。目标设备没有准备好调试。请检查配置位设置并在继续之前对设备进行编程。这种故障最常见的原因是振荡器和/或PGC/PGD设置。我还能做些什么来解决这个问题?我试着查看设备配置。我打开了背景调试器启用(调试),因为它看起来可能是它,但结果是相同的。请让我知道如何修复这一点。谢谢!
以上来自于百度翻译 以下为原文 I succeeded in installing MPLAB Harmony v.2.02, which gave me access to the Board Support Package for the MX470 Curiosity. Still getting the same error from the debugger when I generate a project however: Programming/Verify complete The target device is not ready for debugging. Please check your configuration bit settings and program the device before proceeding. The most common causes for this failure are oscillator and/or PGC/PGD settings. What else can I try to fix this? I tried looking through the device configuration. I turned on background debugger enable (DEBUG), since that seemed like it might have been it, but the result was the same. Please let me know how to fix this. Thanks! |
我注意到,在属性中,支持的调试标题下拉菜单是灰色的,以给出问题的线索。
以上来自于百度翻译 以下为原文 I notice that in properties the supported debug header drop-down menu is greyed out, in case that gives any clue as to what the problem might be. |
您必须使用2.02.xx MHC插件。它包含在安装中。关于如何安装它或在自述文件中的说明。2.02b是β-它自身。但许多司机已经被列为阿尔法或贝塔多年,即使在V1.10
以上来自于百度翻译 以下为原文 The you must use the 2.02.xx MHC plugin. It is included with the install. the instructions on how to install it or in the README file. 2.02b is beta it self. But many drivers have been listed as alpha or beta for years, even in V1.10 |
我使用的是2.02 MHC插件。这是我在早先的帖子中所说的,我已经成功安装了2.02个,如果我不清楚,抱歉。使用这个,我可以用MX470好奇BSP创建一个新项目,但是调试仍然失败,正如我上面提到的,在Project Projts Win中的ExpDebug调试头下拉菜单。道琼斯公司已经破产了。我想在它工作之前我需要配置别的东西。
以上来自于百度翻译 以下为原文 I am using the 2.02 MHC plugin. That is what I meant in my earlier post saying I had successfully installed 2.02, sorry if I was unclear. Using this I am able to create a new project with the MX470 Curiosity BSP, but debugging still fails, and as I stated above the supported debug header drop-down menu in the project properties window is greyed out. I guess I need to configure something else before it will work. |
有什么地方可以找到调试器需要的振荡器设置吗?我似乎找不到任何信息。查看好奇心板的示意图,我注意到USB调试器连接到MX470上的MCLR引脚,以及ASPGEC/PGED。MCLR引脚只是一个复位引脚,所以我不认为有问题。和声配置器提供ICE/ICD COMM频道选择(ICSEL):ICSU-PGX1,ICSU-PGX2(默认)和ICSU-PGX3的选项。是否需要选择其中的一个?我猜是这个引脚配置还是时钟?
以上来自于百度翻译 以下为原文 Is there somewhere that I can find out what oscillator settings the debugger needs? I can't seem to find that information anywhere. Looking at the schematics for the Curiosity Board I notice that the u*** debugger is connected to an MCLR pin on the MX470, as well as PGEC/PGED. The MCLR pin is just a reset pin so I don't think there is a problem there. The Harmony Configurator gives the option of ICE/ICD Comm Channel Select (ICESEL): ICS_PGx1, ICS_PGx2 (the default), and ICS_PGx3. Is there a specific one of these that needs to be selected? I am guess it is either this pin configuration or the clock? |
McLean不仅仅是个别针。它是VPP和编程的一部分。2.02的好奇心板有样本项目吗?你不能调试,但是你能编写这个程序吗?使用你的好奇心PCB上的调试针。
以上来自于百度翻译 以下为原文 McLean is not just a rest pin. It is VPP and part of programming. Is there a sample project for the curiosity board in 2.02? You can't debug, but can you program the board? Use The debug pins that are conneted on your curiosity pcb. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 10:42 , Processed in 1.449812 second(s), Total 108, Slave 91 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2382
