电子发烧友论坛|
我几周没用过MPLAB了。上次我用的时候,一切都很好。现在我打开了我一直在做的同一个项目,IDE找不到任何东西。编译器没有问题,但是IDE在无法识别任何东西和到处标记错误时失去了很多价值。我以前见过这个问题,过去经常来来去去,但自从我看到它已经有一段时间了。我已经附加了一个屏幕截图来显示我在说什么。我今天从3.51开始,升级到3.55。两者都有同样的问题。我还安装了3.50个,所以我试过了。同样的问题。我正在运行Windows 7 64位。Java刚刚更新到1.80.1212.有人知道这有没有解决办法?
以上来自于百度翻译 以下为原文 I haven't used MPLAB in a few weeks. Last time I used it everything was fine. Now I open the same project I'd been working on and the IDE can't find anything. No problem with the compiler, but the IDE loses a lot of its value when it can't recognize anything and flags errors everywhere. I've seen this problem in the past and it used to come and go pretty frequently but it's been a while since I've seen it. I've attached a screen shot to show what I'm talking about. I started today with 3.51 and upgraded to 3.55. Same problem with both. I also still have 3.50 installed so I tried it. Same problem. I'm running Windows 7 64-bit. Java just updated itself to 1.8.0_121. Anybody have any idea whether there's a fix for this? Attached Image(s) |
8个回答
在IDE中找不到标题和东西,但是编译器工作?它做了很多,它总是这样做。你可以试着清理缓存,看看它是否修复了。
以上来自于百度翻译 以下为原文 Not Finding headers and stuff in the IDE, but the Compiler works? It doe that a lot, It has always done this. You can try clearing the caches and see if it fixes it. |
谢谢,无济于事。多么令人沮丧。它已经工作很长时间了…
以上来自于百度翻译 以下为原文 Thanks, doesn't help. How frustrating. It had been working well for so long... |
后续,这似乎是项目特定的。今天我又开了一个项目,很好。我昨天工作的项目仍然是一团糟。昨天我清除了应用程序缓存(C:UsvsUrrEsAppDATaStudioMPLABIDIDCache DEV),这没有帮助。是否还有一个可以缓存的项目缓存?
以上来自于百度翻译 以下为原文 Following up, this appears to be project specific. I opened another project today and it's fine. The project I was working on yesterday is still a mess. I cleaned out the application cache yesterday (C:UsersusernameAppDataLocalmplab_ideCachedev) and that didn't help. Is there also a project cache that can be cleaned? |
[不幸的是,由于某种原因,我不能将自己的帖子标记为答案,但这是我的答案。在“关于”框中只列出了一个缓存,但该项目已被分配了XC32编译器的较旧版本。当我把它指向当前版本时,问题就消失了。
以上来自于百度翻译 以下为原文 [UNFORTUNATELY I CAN'T MARK MY OWN POST AS AN ANSWER FOR SOME REASON, BUT THIS WAS THE ANSWER FOR ME] Only one cache listed in the About box, but this project had been assigned an older version of the XC32 compiler. When I pointed it to the current version the problem went away. |
不知道,但是你可以尝试三件事:1)试着在那个文件中打破一个包含语句,然后等待解析器启动,然后修复它。这通常是有帮助的。2)检查包含目录。例如AT:Project Projt≫Guang.Gt;Source Foldersand:Project Projt&GT:CONF:No.Gt;XC32(Global Opvesty)& gt;XC32 GCC & Gt;选项类别:预处理和消息& Gt;包括DIRTORES3),有时也包括更直接地使用的标准库。帮助EMS。例如,如果您使用UIT88T和UIT64 64 T,请尝试在同一文件或相应的头文件等中包含和lt;Stdit.h & gt;
以上来自于百度翻译 以下为原文 Don't really know, but there might be three things you could try: 1) Try breaking an include statement in that file, and wait until the parser starts, then repair it. Pretty often this helps. 2) Check your include directories. For example at: Project Properties > General > Source Folders and at: Project Properties > Conf: whatever > XC32 (Global Options) > xc32-gcc > Option categories: Preprocessing and messages > Include directories 3) Sometimes including the used standard libraries more directly also seems to help. For example, if you are using uint8_t and uint64_t, try including |
谢谢,如果这些事情再次发生,这些都是很好的尝试。在这种情况下,当我切换编译器版本时,问题就消失了(见上面的几篇文章)。
以上来自于百度翻译 以下为原文 Thanks, these will be good things to try if (when) this happens again. In this case the problem went away when I switched compiler versions (see a few posts above). |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
508 浏览 0 评论
5813 浏览 9 评论
2351 浏览 8 评论
2238 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3545 浏览 3 评论
1161浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
508浏览 0评论
/9
GMT+8, 2025-12-14 18:05 , Processed in 0.769778 second(s), Total 58, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2315
