电子发烧友论坛|
所以下面是一个有趣的描述,我正在尝试了解最新的调试PIC32,所以这怎么能使用?它意味着什么,如果UART在应用程序停止时继续“运行”,它会有什么帮助?我的意思是,如果停止,应用程序不能发送或接收字符,对吗?你什么时候用这个?谢谢。***21.153在调试模式中运行FRZ位(UXMODE和LT;14和GT),在调试模式下CPUIS执行调试异常代码(即应用程序停止)时确定UART模块是否运行或停止。具体而言,FRZ位以以下方式影响操作:1,该模块冻结其操作,并且在调试模式下停止应用时,不改变UUART模块的状态。模块在应用程序恢复执行后恢复其操作。如果FRZ=0,即使在调试模式下应用程序停止,模块也继续运行。
以上来自于百度翻译 以下为原文 So the below is an interesting description, and I'm trying to understand the latest in debugging my PIC32, so how can this be used? What does it mean, how does it help, if the UART continues to "run" while the application is halted? I mean, the application can't send or receive characters if it is halted, right? When would you use this? Thank you. *** 21.15.3 Operation in DEBUG Mode The FRZ bit (UxMODE<14>) determines whether the UART module runs or stops while the CPU is executing DEBUG Exception code (i.e., the application is halted) in DEBUG mode. Specifically, The FRZ bit affects operation in the following manner: • If FRZ = 1, the module freezes its operations and make no changes to the state of the UART module when the application is halted in DEBUG mode. The module resumes its operation after the application resumes execution. • If FRZ = 0, the module continues to run even when application is halted in DEBUG mode. |
6个回答
在收到任何炭后醒来?还是自动波特叫醒?
以上来自于百度翻译 以下为原文 Pois***ily, a wakeup upon receiving any char? or an auto-baud wakeup? |
谢谢。我从睡眠模式中听到了“唤醒”(还有另一个设置在休眠模式下继续运行),但从未脱离“调试异常”模式。有趣。
以上来自于百度翻译 以下为原文 Thanks. I've heard of "wake up" from sleep mode (and there is another setting for continuing to run in sleep mode) but never out of "debug exception" mode. Interesting. |
当FRZ=0时,如果UART在调试器停止时发送字符,则传输完成。否则,它会冻结任何正在进行的。我想。咧嘴笑:
以上来自于百度翻译 以下为原文 With FRZ == 0, if the UART is transmitting a character when the debugger halts, the transmission completes. Otherwise it freezes at whatever bit is is on. I think. grin: |
哦,我明白了…所以这是挤出最后几个字节的方法…也许是沟通它进入异常模式的原因的一种方式?这是有道理的。
以上来自于百度翻译 以下为原文 Oh I see... so it's a way to squeeze out the last few bytes... perhaps a way to communicate the reason that it entered exception mode? That would make sense. |
哦,这是“调试模式”。对不起,我感觉不太舒服。
以上来自于百度翻译 以下为原文 oh it was "in debug mode". Sorry, I don't feel very well. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1097浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 08:01 , Processed in 0.755349 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
181
