电子发烧友论坛|
我一直在使用HP 8756A。
我找不到任何驱动程序,所以我用labview 2011编写了我的VISA驱动程序。执行读取功能后,我一直遇到锁定问题。 输入命令'OD'并读取所有401点后,屏幕上出现“数据转储”。 从这一点开始,我无法发送任何命令或检索任何数据。 当我使用“OI”命令进行识别时,HP 8756A再次锁定! 我已经附加了程序来调用和检索数据,以防它在我的编程中。 谢谢你的帮助 以上来自于谷歌翻译 以下为原文 I've been working with the HP 8756A. I could not find any driver for it and so I wrote my VISA driver by LabVIEW 2011.I have been having problems with it locking up after performing a read function. After entering command 'OD' and reading all 401 points, "Data Dump" appears on the screen. From this point on I can not send any command or retrieve any data. When I use “OI” command for identification, HP 8756A locked up again!!! I have attached the program to call for and retrieve the data in case it is in my programming. Thanks for any help 附件
1个回答
最有可能的是,你没有阅读所有401分......或者如果你是,那么终止可能不正确。
请记住,数百个其他人已经开始使用它,因此问题很可能出在您的代码和/或配置上。 以上来自于谷歌翻译 以下为原文 Most likely, you are not reading all 401 points...or if you are, then the termination may not be correct. Remember that hundreds of others have gotten this to work, so the problem is mostly likely with your code and/or configuration. |
只有小组成员才能发言,加入小组>>
237 浏览 0 评论
1859 浏览 0 评论
2752 浏览 1 评论
2655 浏览 1 评论
2477 浏览 5 评论
1859浏览 0评论
431浏览 0评论
248浏览 0评论
/9
GMT+8, 2025-12-11 08:26 , Processed in 0.633011 second(s), Total 43, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2618
