您好,我正在使用N9020A Tektronix RSA5103A信号分析仪来获取信号频谱;
我想做的是执行信号的IFFT。 不幸的是,我获得的数据中缺少阶段信息。 还有另一种获取频谱幅度和相位的方法,可能是IQ测量吗? 有了IQ,我将获得什么类型的数据? 那么可以用matlab简单地进行IFFT吗? 预先感谢您的帮助。 干杯,塞丽娜 以上来自于谷歌翻译 以下为原文 Hello, I'm using N9020A Tektronix RSA5103A Signal Analyzer to get the spectrum of a signal; what I would like to do is to perform an IFFT of the signal. Unfortunaltely the phase information is missing in the data that I acquired. There is another way to acquire magnitude and phase of the spectrum, maybe with an IQ measurement? With the IQ what type of data I'm going to acquire? Then it will be possible to simply do an IFFT with Matlab? Thank you in advance for your help. Cheers, Serena |
1个回答
嗨Serena - 对于N9020A,您将需要使用IQ波形测量并捕获感兴趣信号的IQ数据。
您可以参考以下手册了解详细信息:http://cp.literature.agilent.com/litweb/pdf/N9060-90029.pdf IQ数据表示I(同相)和q(正交)的值 )时域中IQ平面上的实信号的分量。 其中I * cos(wt)+ jQsin(wt)表示时域信号而Sqrt(I ^ 2 + Q ^ 2)是时域信号的幅度而Arctan(I / Q)是时间的相位 域信号对于特定样本。 Matlab具有复杂的FFT功能,允许复数值作为FFT功能的输入。 您将获得信号的复频域表示作为函数的输出。 您可以将此功能与IFFT功能一起使用,以便在时域中恢复原始实信号。 有更多雄辩的方法,但这种方法是直观的问候 - 以上来自于谷歌翻译 以下为原文 Hi Serena - For the N9020A, you will want to use the IQ Waveform measurement and capture the IQ Data of the signal of interest. You can reference the manual below for the details: http://cp.literature.agilent.com/litweb/pdf/N9060-90029.pdf The IQ Data is represents the values of the I (in-phase) and q (quadrature) components of the real signal on the IQ plane in the time domain. Where I*cos(wt)+jQsin(wt) is represents the time domain signal And Sqrt(I^2+Q^2) is the magnitude of the time domain signal And Arctan(I/Q) is the phase of the time domain signal For a particular sample. Matlab has an complex FFT function that allows complex values as inputs to the FFT function. You will get the complex frequency domain representation of the signal as an output of the function. You can use this with the IFFT function to get the original real signal back in the time domain. There are more eloquent methods, but this approach is intuitive Regards - |
只有小组成员才能发言,加入小组>>
1091 浏览 0 评论
2311 浏览 1 评论
2100 浏览 1 评论
1974 浏览 5 评论
2844 浏览 3 评论
855浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
625浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
724浏览 0评论
1413浏览 0评论
1091浏览 0评论
GMT+8, 2024-10-6 13:55 , Processed in 1.268150 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
