电子发烧友论坛|
嗨,我想把我的应用程序加载到一个特殊的ROM区域。为此,我想改变默认链接器来使用我自己的。但是我在冲突中遇到了错误。我的设备是十六进制和失败编程。我的设备是PIC32 MZ2048 EFG100(ChipKit Wifire)。这是我在链接器上的更改:但是我收到了错误信息:我错过了什么吗?问候,洛根
以上来自于百度翻译 以下为原文 Hi, I am trying to load my application to a special ROM region. For that, I would like to change the default linker to use my own. but i got an error with conflict .hex and failed programming my device. My device is the PIC32MZ2048EFG100 (ChipKit Wifire) Here is my change on the linker : kseg0_program_mem (rx) : ORIGIN = 0x9D000000, LENGTH = 0x200000 kseg0_boot_mem : ORIGIN = 0x9FC004B0, LENGTH = 0x0 to kseg0_program_mem (rx) : ORIGIN = 0x9FC00000, LENGTH = 0x73000 kseg0_boot_mem : ORIGIN = 0x9FC73000, LENGTH = 0x0 but I got error message : Target voltage detected Target device PIC32MZ2048EFG100 found. Device ID Revision = A1 Failed to read device Device Erased... Programming... The following memory area(s) will be programmed: program memory: start address = 0x0, end address = 0x1fff boot config memory configuration memory Configuration memory Address: 0x1fc0ff4c Expected Value = 0x00208021, received value = 0x00208023 Failed to program device Did I miss something ? Regards, Logan |
2个回答
0x9FC000的YouKS00SuffyTym MEM可能与0xBFC000开始重叠。因为这些是虚拟地址,它们映射到相同的物理地址0x1fc000。
以上来自于百度翻译 以下为原文 Your kseg0_program_mem from 0x9FC00000 might overlap kseg1_boot_mem starting from 0xBFC00000. Because those are virtual addresses and they map to the same physical address 0x1FC00000. |
哦,是的,这是我的坏。所以启动闪存太低,我的应用程序,我会分裂程序闪存在两个部分,然后)谢谢!
以上来自于百度翻译 以下为原文 Oh yes, that's my bad. So Boot Flash is too low for my app, i'll split Program flash in two parts then ;) Thanks ! |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:19 , Processed in 0.736737 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3660
