电子发烧友论坛|
hello everone:我有一个基于微博的产品(包括axi4,MCB_DDR2,axi_intc,axi_ethernetlite,axi_timer等)产品在spartan-6 FPGA上运行,它使用xilkernel上的lwip(插槽模式下的lwip)。但是,我可以'
创建bsp,因为它有问题。 “为Xilinx MAC编译lwIP适配器”contrib / ports / xilinx / sys_arch.c:63:35:错误:'MAX_SEM'未声明(不在函数中)make [1]:*** [contrib / ports / xilinx / sys_arch.o]错误1make [1]:由于错误目标“libs”并未重新创建。“编译cpu”错误:EDK:369 - 使目标“libs”失败错误:EDK:3418 - 运行时出错 make.make:*** [microblaze_0 / lib / libxil.a]错误2make:由于错误目标“all”并未重新创建。 我该怎么做才能解决它。 先谢谢你。 以上来自于谷歌翻译 以下为原文 hello everone: I have a microblaze-based(include axi4、MCB_DDR2、axi_intc、axi_ethernetlite、axi_timer ang so on )product running on a spartan-6 FPGA which uses lwip on the xilkernel (lwip in socket mode).But,i can't create the bsp ,because there are something wrong with it. "Compiling lwIP adapter for Xilinx MAC" contrib/ports/xilinx/sys_arch.c:63:35: error: 'MAX_SEM' undeclared here (not in a function) make[1]: *** [contrib/ports/xilinx/sys_arch.o] 错误 1 make[1]: 由于错误目标“libs”并未重新创建。 "Compiling cpu" ERROR:EDK:369 - make failed for target "libs" ERROR:EDK:3418 - Error(s) while running make. make: *** [microblaze_0/lib/libxil.a] 错误 2 make: 由于错误目标“all”并未重新创建。 what should i do to solve it. Thank you in advanced. |
9个回答
喜
更简单的方法是参考xapp1026参考设计。 --hem -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 hi, an easier way to figure this out is to refer to xapp1026 reference design. --hem ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
喜
更简单的方法是参考xapp1026参考设计。 --hem -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 hi, an easier way to figure this out is to refer to xapp1026 reference design. --hem ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
喜
您可以参考http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/ug758.pdf第10页中显示的MSS设置。 --hs -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 hi, you can refer the MSS setting shown in page 10 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_4/ug758.pdf --hs ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
非常感谢〜
我已经提到了xapp1026参考设计。由于不同的芯片,我必须重新设计它。现在,我正在阅读说明(在EDK的MicroBlaze处理器实例设计中的Xilkernel)。如果我不明白该怎么做,我 希望我能得到你的帮助。我是初学者,谢谢〜 以上来自于谷歌翻译 以下为原文 thank you very much~ i have referred to xapp1026 reference design.Due to different chip,i have to redesign base on it.now,i am reading the illustration(Xilkernel on a MicroBlaze Processor Example Design in EDK).If I don't understand how to do, I hope i can get your help.I am a beginner,thanks~ |
我记得xapp1026参考设计使用基于freeRTOS操作系统的套接字模式,但我想用xilkernel系统。我知道并不全面。谢谢你的分享。
以上来自于谷歌翻译 以下为原文 i remember the xapp1026 reference design use socket mode base on freeRTOS OS , but i wang ues xilkernel system.what i know is not comprehensive.Thank you for sharing. |
你好,你还在吗?
我已经阅读了手册,我发现我的mss文件与他给出的文件完全不同。我打开了Boo Support Package Settings模块,但没有地方设置参数“MAM_SEM”。这是我的MSS文件。 system.mss 2 KB 以上来自于谷歌翻译 以下为原文 Hello, are you still here? I have read the manual,I find My mss file is completely different from the file he gave.I open the Board Support Package Settings module,but no place to set the parameter “MAM_SEM”.This is my MSS file. |
好。
我已经解决了我的问题。这只是一个xilkernel配置问题。非常感谢你。 以上来自于谷歌翻译 以下为原文 OK. I have solved my problem.This is just a xilkernel configuration problem.Thank you very much. |
higy343279479
很高兴知道这个问题已经解决了。 请将帖子标记为已解决。 这可以是对其他用户的引用。 --hs -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 hi gy343279479 glad to know that the issue is solved. please mark the post as solved. this can be a reference to other users. --hs ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我遇到同样的问题,你可以发布解决问题的方式吗?
以上来自于谷歌翻译 以下为原文 I meet the same problem, could you post the way you solve the problem? |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 04:11 , Processed in 0.923407 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2878
