你好,
我正在寻求帮助,为相当简单的应用选择合适的FPGA。 我想将FPGA用作无线射频模块的简单预处理器。 主要目的是在传输到无线模块之前抽取过采样数据。 具体来说,我需要FPGA来执行以下功能: (1)接收多通道数字数据 - 有16个数据通道通过SPI串行接口进入FPGA。 数字数据被过采样(10kHz采样率)。 每个样本16位。 (2)将多通道数据抽取/下采样4倍(可能使用CIC滤波器,或CIC + FIR补偿滤波器或多相)。 (3)通过并行接口或可能通过SPI将下采样数据传输到无线模块。 (4)可能需要在输入端(抽取之前)和/或输出端(在抽取之后,在传输到无线模块之前)使用FIFO缓冲器。 是否建议Xilinx FPGA器件适合该应用? 另外,是否有推荐的方法来估算所需的门数/资源(只是粗略的球场估计就足够了)? 对此应用程序的任何其他想法和反馈将不胜感激。 谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I am seeking assistance in selecting an appropriate FPGA for a fairly straightforward application. I would like to use the FPGA as a simple pre-processor to a wireless RF module. The main purpose is to decimate oversampled data before transferring to the wireless module. Specifically, I need the FPGA to perform the following functions: (1) Receive multichannel digital data – there are 16 data channels coming to the FPGA via SPI serial interface. Digital data is oversampled (10kHz sampling rate). 16 bits per sample. (2) Decimate/downsample the multichannel data by a factor of 4 (probably using a CIC filter, or CIC + FIR compensation filter, or polyphase). (3) Transfer the downsampled data to the wireless module via a parallel interface, or possibly via SPI. (4) May need FIFO buffers at the input (prior to decimation) and/or at the output (after decimation, prior to transferring to wireless module). Is there a recommendation for what Xilinx FPGA device would be a good fit for this application? Also, is there a recommended method for estimating gate count / resources required (just a rough ballpark estimate would be sufficient)? Any other thoughts and feedback for this application would be greatly appreciated. Thank you! |
1个回答
Ĵ,
我怀疑最小的Artix 7部分能满足您的需求, 较旧的Spartan 7最小部件也可以使用。 你想制作或购买电路板吗? http://www.xilinx.com/products/boards-and-kits/arty.html http://www.xilinx.com/products/boards-and-kits/ek-s6-sp605-g.html Digilentinc.com也有廉价的电路板。 http://store.digilentinc.com/fpga-programmable-logic/system-boards/ 安富利也有自己的董事会 https://products.avnet.com/shop/en/ema/development-kits#facet:&inStock:&productBeginIndex:0&orderBy:&pageView:list&minPrice:&maxPrice:&pageSize: 10安培; selectedAttr:安培; Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 j, I suspect the smallest Artix 7 part would meet your needs, The older Spartan 7 smallest part would also work. Do you wish to make, or buy a board? http://www.xilinx.com/products/boards-and-kits/arty.html http://www.xilinx.com/products/boards-and-kits/ek-s6-sp605-g.html Digilentinc.com also has inexpensive boards. http://store.digilentinc.com/fpga-programmable-logic/system-boards/ Avnet also has their own boards https://products.avnet.com/shop/en/ema/development-kits#facet:&inStock:&productBeginIndex:0&orderBy:&pageView:list&minPrice:&maxPrice:&pageSize:10&selectedAttr:& Austin Lesea Principal Engineer Xilinx San Jose |
只有小组成员才能发言,加入小组>>
2429 浏览 7 评论
2831 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2298 浏览 9 评论
3378 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2468 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1359浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
596浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
460浏览 1评论
2013浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 02:31 , Processed in 1.062467 second(s), Total 44, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
