对于Series-7,有任何方法只使用HDL仿真来进行HWITL。
我知道matlab / Simulink,但我只是想使用Vivado模拟器,或者使用Modelsim,并且能够模拟KC704板上的设计。 以上来自于谷歌翻译 以下为原文 For Series-7 is there any way of doing HWITL just using HDL simulation. I know about Matlab/Simulink but i just want to use either the Vivado simulator, or using Modelsim, and have the ability to simulate a design on the KC704 board. |
2个回答
通常hwitl指的是fpga平台是hw和前端工具将模拟代码(m-> rtl)提交给hw,关键是运行模拟更快,因为fpgas执行rtl比pc可以执行m更快
码。 在你的情况下,如果你正在模拟rtl所以fpga不是hw那么它是什么?你想要将rtl模拟的输出连接到一个硬件说和引导并看到它打开/关闭时 你运行模拟? 这个模拟的重点是,您可以观察所有输出并控制rtl模拟中的所有输入。 如果要获得受控hw的实际行为,那么你应该注意到rtl模拟运行速度非常慢,除非界面非常简单并且与时间无关,否则它实际上无法跟上外部hw。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 usually hwitl refers to the fpga platform being the hw and the front-end tool submitting the simulation code (m->rtl) to the hw and the point is to run the simulations faster as fpgas execute rtl much faster than a pc can execute m code. In your case if you are simulating the rtl so the fpga is not the hw which is itl what is it? do you want to connect the output of the rtl simulation to a piece of hardware say and led and see the it on/off when you run the simulation? what is the point of this simulation as you can observe all outputs and control all inputs in the rtl simulation. If the point is to get the real behavior of controlled hw, then you should notice that the rtl simulation will run extremely slowly and it really won't be able to keep up with external hw unless the interface is extremely simple and independent of timing.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
它是sysgen HWITL的概念,它使用simulink源和接收器,但在纯RTL环境中。
我正在尝试进行视频模拟,我想加快模拟速度。 但它似乎没有任何存在。 虽然Vivado模拟器会是你可以做到这一点的地方,但我会感到非常震惊。 以上来自于谷歌翻译 以下为原文 its the concept of sysgen HWITL and where it uses simulink sources and sinks but in a pure RTL enviroment. I'm trying to do Video simulations and I want to speed up the simulation. But it looks like nothing exists. I'm surprosed as I would have though Vivado Simulator would be the sort of place you could do this. |
只有小组成员才能发言,加入小组>>
2374 浏览 7 评论
2790 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2257 浏览 9 评论
3331 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2422 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
747浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
533浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
356浏览 1评论
750浏览 0评论
1951浏览 0评论
GMT+8, 2024-11-19 11:39 , Processed in 1.163619 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
