电子发烧友论坛|
受试者说明了一切。而不是弹出工具栏提示,MPLAB关闭。没有错误,没有警告,只是关闭。MPLAB X IDE V3.55 Windows 10 64位(当前)Java版本8更新121其他人体验到这一点吗?有什么修正吗?
以上来自于百度翻译 以下为原文 Subject says it all. Instead of popping up a toolbar hint, MPLAB closes. No errors, no warnings, just closes. MPLAB X IDE v3.55 Windows 10 64-bit (current) Java version 8 update 121 Anyone else experience this? Any fixes? |
5个回答
整个MPLAB X IDE的屏幕截图,包括仪表板,实际上都会说出来。说明哪个工具栏允许复制和解析。
以上来自于百度翻译 以下为原文 Screenshot of entire MPLAB X IDE, including Dashboard, actually would say it all. Stating which toolbar would allow replication and resolution. |
“说明哪个工具栏允许复制和解析”“任意/所有工具栏”。主工具栏。编辑器工具栏。不管我是在代码编辑器还是代码配置器中,实际上,即使是在标签上徘徊(任何/所有标签)都会使它“自动关闭”。我试图上传一个图像,但显然我没有权限访问HTTP://www. McCHIP.COM/FUMMS/POST.ASPX。在这个服务器上。参考文献18:E7E33 F171492081763.66 F3B“屏幕截图:http://www. Doffbox…com /sEHMSX/MPLABX.PNG?DL=0
以上来自于百度翻译 以下为原文 "Stating which toolbar would allow replication and resolution." ANY/ALL toolbars. Main toolbar. Editor toolbar. Doesn't matter if I'm in the code editor or Code Configurator. In fact, even hovering over the tabs (ANY/ALL tabs) will make it "auto-close." See Screenshot: https://www.dropbox.com/s...sehmsx/mplabx.png?dl=0 |
对不起,您的经验。WI10没有太多的活动。验证显示设备驱动程序,然后可能清除用户和临时文件夹,如框中所示。
以上来自于百度翻译 以下为原文 Sorry for your experience. Not much activity with Win10. Verify display device drivers, then maybe clear user and temp folders as shown in About box. |
W. Lang --谢谢你的建议。我以后再试试。经过整整一天的生产力下降,我必须找到另一个解决方案来保持项目向前发展。J. Nickerson -我的系统不是出血边缘,但它不是一个狗狗。几岁的I7@ 4GHz,8G RAM,500 G自由驱动空间。既然你有V3.55的工作,我必须假设这是一个与我的机器的可比性问题。谢谢答复。
以上来自于百度翻译 以下为原文 W. Lang -- thanks for the ideas. I will try them later. After a full day of lost productivity, I had to find another solution to keep the project moving forward. J. Nickerson -- My system is not bleeding edge, but it's not a pooch. Couple year old i7 @ 4GHz, 8G RAM, 500G free drive space. Since you have v3.55 working, I have to assume it's a comparability issue with my machine. Thanks for the replies. |
我有幸使用j控制台来查看Java的运行情况。我不是Java专家,我是谷歌需要的Java问题。http://DOCS.Oracle…com /ja…nMealth/JCONSOL.HTML
以上来自于百度翻译 以下为原文 I have had some luck using jconsole to see what is going on with java. I am not a java expert, I google what I need as java problems arise. http://docs.oracle.com/ja...nagement/jconsole.html |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
495 浏览 0 评论
5808 浏览 9 评论
2347 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3542 浏览 3 评论
1153浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1118浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
886浏览 1评论
500浏览 0评论
/9
GMT+8, 2025-12-11 22:23 , Processed in 0.849486 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1047
