HI专家,
我试图找到一种方法来根据源代码文件中的注释生成源代码文档。 例如,我有一个带注释的附加代码文件。 我想基于html / chm文件制作一个文档,所以我可以轻松地完成我的代码工作。 也是赛灵思用于代码文档的软件。 先谢谢你。 PB_Debouncer.v 3 KB 以上来自于谷歌翻译 以下为原文 HI Experts, I am trying to find a way to generate source code documentation based on comments in the source code file. For example I have a attached code file with comments. I want to make a document based on html/chm files, so i can nevigate through my code work easily. Also what software Xilinx use for their code documentation. Thank you in advance. PB_Debouncer.v 3 KB |
4个回答
基于注释的代码文档是什么意思。
理想情况下,你可以在vivado或任何好的编辑器(记事本++)中打开文件,通过实际代码和注释之间的不同颜色编码轻松地阅读它。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 What do u mean by code documentation based on comments. ideally you can open the files in the vivado or any good editor (notepad++) to read through it easily, by different color coding between the actual code and comments.Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
你可能意味着像doxygen这样的东西。
您可以在这里找到更多信息。 这种事情是可以的,在我看来,你必须为theparser准备你的代码,如果你试图追溯生成大型项目的文档,这可能会有点痛苦。 ----------“我们必须学会做的事情,我们从实践中学习。” - 亚里士多德 以上来自于谷歌翻译 以下为原文 You probably mean something like doxygen, I expect. You can find more information here. This kind of thing is OK, in my opinion but you have to prepare your code for the parser, which can be a bit of a pain if you are trying to retroactively generate documentation for a large project. ---------- "That which we must learn to do, we learn by doing." - Aristotle |
是的我说的是像doxygen这样的东西。
但doxygen不支持verilog语言。 我试过了,但遗憾的是寄存器的注释不起作用,只有简短的描述适用于模块,并且总是。是否有专门为HDL语言制作的特殊软件。 xilinx使用什么? 以上来自于谷歌翻译 以下为原文 Yes I am talking about thing like doxygen. But doxygen does not support verilog language. I tried it but unfortunately comments for registers are not working, only brief description is working for modules and always. Is there any special software made specially for HDL languages. What xilinx uses? |
只需使用您最喜欢的搜索引擎,您就可以获得更快的积极响应。
只需几分钟即可获得以下可能有用的链接: Verilog转换为HTML doxverilog - doxygen的Verilog解析器 ----------“我们必须学会做的事情,我们从实践中学习。” - 亚里士多德 以上来自于谷歌翻译 以下为原文 You'd probably get a faster positive response by simply using your favourite search engine. Just a few minutes is all it took to come up with the following links which may be useful: Verilog to HTML doxverilog - Verilog parser for doxygen ---------- "That which we must learn to do, we learn by doing." - Aristotle |
只有小组成员才能发言,加入小组>>
2134 浏览 7 评论
2590 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2063 浏览 9 评论
3135 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2166 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
399浏览 1评论
1503浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2164浏览 0评论
495浏览 0评论
1618浏览 0评论
GMT+8, 2024-3-29 14:33 , Processed in 1.022936 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
