电子发烧友论坛|
我的任务是重建一台烧毁的硬盘并用它取出硬盘。
我现在已经建立了系统并且正在运行,但我需要重新安装计算机上的软件才能使用他们为该主板编写的程序。 我甚至不确定该主板是否仍然有效,但不管怎样,我仍然需要该软件。 有人可以给我一个链接,我可以下载完整版的6.1i,以便我可以测试板和PC吗? 谢谢 干草堆 以上来自于谷歌翻译 以下为原文 I have been tasked to rebuild a PC that burnt up and took the hard drive out with it. I have the system built now and is working but I need to reinstall the software that was on the computer in order for them to use their program that was wrote for that board. I am not even sure if the board still works, but either way, I still need the software. Can someone provide me a link to where I can download a full version of 6.1i so I can test the board and PC? Thanks Rick |
2个回答
你好
检查以下链接 http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/archive.html 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi Check below link http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/archive.html Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. ---------------------------------------------------------------------------------------------View solution in original post |
只有小组成员才能发言,加入小组>>
3150 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4109 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1365浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1205浏览 1评论
/9
GMT+8, 2025-12-17 22:28 , Processed in 0.733159 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3957
