电子发烧友论坛|
我使用MPLAB X 3.51针对PIC18F27 K40,它具有1024字节的EEPROM。我用PIDIT 3作为程序员,XC 1.41作为编译器。我试图为配置设置保留一些字节的EEPROM,这是我在其他图片中成功完成的。在属性中,我选择“保存EEPROM内存”,但是当我键入范围时,文本字段变红,屏幕底部的错误信息显示“未知”。原因。我已经尝试了一系列的变化范围,但始终得到相同的错误。我还尝试了设置“自动选择内存和范围”到手动,以及在“允许选择3选择”,但同样的错误。我尝试上传的属性窗口的图像,但有服务器错误。有什么想法?
以上来自于百度翻译 以下为原文 I am using MPLAB X 3.51 targeting a PIC18F27K40 which has 1024 bytes of EEPROM. I am using PICkit 3 as the programmer, and XC 1.41 as the compiler. I am trying to 'preserve' a few bytes of EEPROM for configuration settings, something that I have successfully done in other PICs. In the properties, I select "Preserve EEPROM Memory" but when I type the range, the text field turns red and the error message in the bottom of the screen shows 'Unknown cause'. I have tried a bunch of variations on the range but consistently get the same error. I have also tried this both by setting the "Auto select memories and ranges" to manual as well as in the 'Allow pickit 3 to select', but same error. I tried to upload an image of the properties window but got a server error. Any ideas? |
4个回答
同样,在这里,用PIC24FV32 KA302 XC16 PK3(FW 1-44-26)X3.55,我确信“保存EEPROM”标志用于自己工作,不需要地址范围吗?但是,我已经尝试过(00—FF),但是出错了,放弃了,把它放在X臭虫列表上。此外,PK3 FW“使用最新”或“手册”不起作用。
以上来自于百度翻译 以下为原文 Same here , with PIC24FV32KA302 XC16 PK3 (fw 1-44-26) X3.55 I am sure 'preserve eeprom' flag used to work on its own , did not need address range ?, but I have tried (00-FF ) but errors out , sort of gave up , put it on the list of X bugs. also the PK3 fw "use latest" or "manual " does not work. |
这些指令显示了0FF的一个例子。当这不起作用时,我尝试了以下方法,并且响应已经是SAM.0—100-200—FF0—FF0—10-40-100-0XFF0—0XFF0—0X100-1XF10FFF0XF
以上来自于百度翻译 以下为原文 The are instructions that show an example of 0-ff. When this didn't work, I tried the following, and the response has been the same. 0-10 0-20 0-FF 0-ff 0-1 0-4 0-100 0-0xFF 0-0xff 0-0x10 0-1xF 10 F FF 0xF |
对于PIC18F27 K40,使用数据表中表11-1中EEPROM所示的地址范围:例如:310000~31000 FrgARDS,戴夫
以上来自于百度翻译 以下为原文 For a PIC18F27K40, use the address range shown for EEPROM in Table 11-1 of the data sheet: For example: 310000-31000f Regards, Dave |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
503 浏览 0 评论
5812 浏览 9 评论
2350 浏览 8 评论
2237 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3544 浏览 3 评论
1160浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
503浏览 0评论
/9
GMT+8, 2025-12-14 08:18 , Processed in 0.773711 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
943
