电子发烧友论坛|
你好,我想把AD77 68的输出数据读入PC机,然后使用SCILAB中的数据。我需要相当高的数据速率(8个信号,每个样本有256个KB,每个样本有4个字节)。ADC的输出是具有2条数据线的SPI和32 MHz的SPI时钟或8条数据线和8MHz的时钟。ADC是SPI主机,是连续发送数据的。我已经把SPI看做像FTTDI芯片和其他厂商的USB桥接器,但是它们不能满足数据速率,有些还需要字节字节之前的地址字节。因为我是一个完整的PIC处女,如果有人合作,我会很高兴。ULD给我一个已经满足我的需求的项目,或者至少需要一些小的修改。如果我需要的不是PIC,那么这样的信息也会有帮助,所以我不会浪费太多的时间自己去发现。提前感谢格尔德。
以上来自于百度翻译 以下为原文 Hi, I want to read the output data from an AD7768 into a PC and then use the data within SCILAB. I need quite a high data rate (8 signals with 256 kSamples each at 4 bytes per sample). The output of the ADC is SPI with 2 data lines and the SPI clock at 32MHz or with 8 data lines and the clock at 8MHz. The ADC is the SPI master and is sending data continously. I have looked after SPI to USB bridges like FTDI-chips and ones from other vendors but they would not meet the data rate and some also need address bytes before the data bytes. As I am a complete PIC virgin, I would be delighted if someone could point me to a project that would already meet my needs or at least need only minor modifications. If what I need is not possibe with a PIC then such info would also be helpful , so I wouldn't waste too much time finding out by myself. Many thanks in advance, Gerd |
2个回答
我已经看到了一些关于音频采样的线索,它们是几年前的,但据我所知,在48千赫的情况下采样两个音频数据是一个艰难的过程。也许你应该寻找一个更快的32位PIC或类似的。
以上来自于百度翻译 以下为原文 I have seen a few threads that were talking about audio sampling, they were a few years old but as far as I could tell it was a struggle to sample two channels of audio data at 48kHz. Maybe you should be looking into a faster 32 bit PIC or similar. |
我不记得任何PIC设备处理硬件中的双或四个SPI接口-也许一些新的设备做,但你需要检查微芯片产品选择页面。只要你离开接口到硬件(即不要尝试敲击界面本身)和每HAPS使用DMA,你不应该有任何问题的高(ISH)传输速率。然而,我怀疑试图让PIC在8毫秒/秒中读取数据,然后处理USB接口(或者甚至通过UART)可能会推动它。这将等于UMAR.苏珊的大约64 Mb/s吞吐量或非常高的波特率。
以上来自于百度翻译 以下为原文 I don't remember any PIC device that handles dual or quad SPI interfaces in hardware - perhaps some of the newer devices do but you wold need to check the Microchip product selection pages. As long as you leave the interface to the hardware (i.e. don't try to bit-bang the interface yourself) and perhaps use DMA, you should not have any problems with high(ish) transfer rates. However I suspect that trying to get a PIC to read in data at 8 MSamples/Sec and then also handle a USB interface (or even through a UART) might be pushing it. That would equate to about 64mBit/Sec throughput or a very high BAUD rate for the UART. Susan |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 05:46 , Processed in 1.868947 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
16579
