这里有一个类似的问题,但没有太多关于这个问题的讨论。
我有一个外部inputclkIN,它被送入CoolRunner II,并且有一个signalclkOUT,它复制了clkIN。 我需要将clkOUT延迟10-15ns,因此它会滞后于clkIN。 此延迟小于clkIN期间。 有人告诉我,我可以通过使用许多缓冲区人为地引入这种延迟并将约束放在信号上,因此优化不会消除它们: 建筑行为主要是 SIGNAL Dummy:STD_LOGIC:='0'; 属性keep:string; 属性保持虚拟:信号为“真”; 开始 假 我不确定我是否正确地设置了所有内容,但我没有看到引入延迟。 如何确保信号Dummy包含所有那些NOT门? 在看到一些延迟之前,我需要多少个这样的门? 关于如何引入比时钟周期短的延迟的任何其他建议? 我希望不使用额外的外部逻辑,并且我不能使PCB的制造时间更长。 以上来自于谷歌翻译 以下为原文 There is a similar question here, but there is not much discussion about the issue. I have an external input clkIN that is fed into the CoolRunner II, and there is a signal clkOUT, that duplicates the clkIN. I need to delay the clkOUT by 10-15ns, so it will lag the clkIN. This delay is less than a clkIN period. I was told that I could introduce such delay artificially by using many buffers and put the constrains on the signal, so the optimisation does not get rid of them: architecture Behavioral of main isSIGNALDummy: STD_LOGIC:= '0';attribute keep: string;attribute keep of Dummy: signal is "true";beginDummy<= NOT(NOT(NOT(NOT(NOT(NOT(NOT(NOT(NOT(NOT((clkIN)))))))))));clkOUT<= Dummy;end Behavioral;I am not sure if I set everything up correctrly, but I do not see a delay being introduced. How do I make sure that the signal Dummy contains all those NOT gates? How many such gates do I need before seeing some delay? Any other suggestions on how to introduce a delay shorter than a clock period? I wish not to use additional external logic and I can not make the trace longer the PCB is already manufactured. |
6个回答
我按原样尝试了你的代码。
这是我看到的: TP1到TP4按预期将Dummy1替换为Dummy4(这只是一个名称更改)。 按预期使用了5个宏单元。 但是,连接不会根据需要串行通过5个宏单元。 优化结果来自fitter报告中的以下等式: TP1 TP2 TP3 TP4 clkOUT 所以我尝试更改代码,以便Dummy1到Dummy4节点改为INOUT端口,并且仍然使用相同的方程式。 (这种综合优化很难)。 最后我添加了一个三态控制输入引脚,使合成器认为Dummy端口真的可以输入并最终得到: - Gabor 在原帖中查看解决方案 cpld_dly.vhd 2 KB 以上来自于谷歌翻译 以下为原文 I tried your code as is. Here's what I see: TP1 through TP4 replace Dummy1 through Dummy4 as expected (this is just a name change). There are 5 macrocells used as expected. However the connections don't go serially through the 5 macrocells as desired. Optimization results in the following equations from the fitter report: TP1 <= clkIN; TP2 <= clkIN; TP3 <= clkIN; TP4 <= clkIN; clkOUT <= clkIN; So I tried changing the code so that the Dummy1 through Dummy4 nodes were INOUT ports instead, and still got the same equations. (This synthesis optimization is tough). So finally I added a tristate control input pin, to make the synthesizer think that the Dummy ports could really be inputs and ended up with this: -- GaborView solution in original post cpld_dly.vhd 2 KB |
这听起来很合理。
但是,我得不到它的工作。 我就是这样设置的: 实体主要是 端口(CLKIN:IN STD_LOGIC; TP1:OUT STD_LOGIC; TP2:OUT STD_LOGIC; TP3:OUT STD_LOGIC; TP4:OUT STD_LOGIC; clkOUT:OUT STD_LOGIC:='0'); 结束主; 建筑行为主要是 SIGNAL Dummy1:STD_LOGIC:='0'; SIGNAL Dummy2:STD_LOGIC:='0'; SIGNAL Dummy3:STD_LOGIC:='0'; SIGNAL Dummy4:STD_LOGIC:='0'; 属性keep:string; 属性保持Dummy1:信号为“true”; 属性保持Dummy2:信号为“true”; 属性保持Dummy3:信号为“真”; 属性保持Dummy4:信号是“真”; 开始 Dummy1 当我检查fitter报告时,我没有看到任何Dummy信号,只看到TP1-4。我也有一个单独的.ucf约束文件。 我是否还必须提供一些保留限制? 如果是这样我该怎么办? 任何猜测为什么这不起作用? 以上来自于谷歌翻译 以下为原文 That sounds reasonable. However, I get not get it to work. This is how I set it up: entity main is Port(clkIN:INSTD_LOGIC;TP1:OUTSTD_LOGIC;TP2:OUTSTD_LOGIC;TP3:OUTSTD_LOGIC;TP4:OUTSTD_LOGIC;clkOUT:OUTSTD_LOGIC:= '0');end main;architecture Behavioral of main isSIGNALDummy1:STD_LOGIC:= '0';SIGNALDummy2:STD_LOGIC:= '0';SIGNALDummy3:STD_LOGIC:= '0';SIGNALDummy4:STD_LOGIC:= '0';attribute keep : string;attribute keep of Dummy1: signal is "true"; attribute keep of Dummy2: signal is "true";attribute keep of Dummy3: signal is "true";attribute keep of Dummy4: signal is "true";beginDummy1<= clkIN;Dummy2<= Dummy1;Dummy3<= Dummy2;Dummy4<= Dummy3;clkOUT<= Dummy4;-- I also added pin assignmentsTP1<= Dummy1;TP2<= Dummy2;TP3<= Dummy3;TP4<= Dummy4;end Behavioral;When I check the fitter report, I do not see any of the Dummy signals, only the TP1-4. I also have a separate .ucf constraint file. Do I have to provide some keep constraints there too? If so how do I do it? Any guesses why this is not working? |
我按原样尝试了你的代码。
这是我看到的: TP1到TP4按预期将Dummy1替换为Dummy4(这只是一个名称更改)。 按预期使用了5个宏单元。 但是,连接不会根据需要串行通过5个宏单元。 优化结果来自fitter报告中的以下等式: TP1 TP2 TP3 TP4 clkOUT 所以我尝试更改代码,以便Dummy1到Dummy4节点改为INOUT端口,并且仍然使用相同的方程式。 (这种综合优化很难)。 最后我添加了一个三态控制输入引脚,使合成器认为Dummy端口真的可以输入并最终得到: - Gabor cpld_dly.vhd 2 KB 以上来自于谷歌翻译 以下为原文 I tried your code as is. Here's what I see: TP1 through TP4 replace Dummy1 through Dummy4 as expected (this is just a name change). There are 5 macrocells used as expected. However the connections don't go serially through the 5 macrocells as desired. Optimization results in the following equations from the fitter report: TP1 <= clkIN; TP2 <= clkIN; TP3 <= clkIN; TP4 <= clkIN; clkOUT <= clkIN; So I tried changing the code so that the Dummy1 through Dummy4 nodes were INOUT ports instead, and still got the same equations. (This synthesis optimization is tough). So finally I added a tristate control input pin, to make the synthesizer think that the Dummy ports could really be inputs and ended up with this: -- Gabor cpld_dly.vhd 2 KB |
这很有效。
非常感谢。 我希望我不必使用外部引脚。 以上来自于谷歌翻译 以下为原文 This works. Thank you so much. I wish I did not have to use external pins. |
有趣的是,在我发布代码之后,我查看了“PADS”到“PADS”的时间,并注意到时序分析器没有看到反馈路径是clkIN路径的延续。
我给出了28 ns的最大延迟时间,并且工具表示它达到3.8 ns,但是查看详细报告它只显示从每个输入到下一个输出的路径,而不是通过反馈后的输出路径的延续 。 我假设您可以通过将各个延迟相加来计算通过该部分的最大延迟,但是从clkIN到clkOUT的路径未被约束覆盖似乎很奇怪。 - Gabor 以上来自于谷歌翻译 以下为原文 It's interesting that after I posted that code I looked at the timing for "PADS" to "PADS" and noticed that the timing analyzer doesn't see the feedback paths as a continuation of the clkIN path. I gave a max delay time of 28 ns, and the tools said it met 3.8 ns, however looking at the detailed report it only showed paths from each input to the next output, not the continuation of the path to the output after that via feedback. I presume that you could calculate the axtual max delay through the part by just adding up the individual delays, but it did seem odd that the path from clkIN to clkOUT was not covered by the constraint. -- Gabor |
只有小组成员才能发言,加入小组>>
2166 浏览 7 评论
2608 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2081 浏览 9 评论
3153 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2197 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
430浏览 1评论
1529浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2180浏览 0评论
511浏览 0评论
1645浏览 0评论
GMT+8, 2024-4-28 18:48 , Processed in 1.017813 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
