ADUC7039 SPI从机模式,收不到主机数据
1.while((PLLSTA&0x2)==0) {} // Ensure That thePLL is locked to the 3% // SysClock=20.48MHz/2=10.24MHz (POWCON:CD=1 by default) /* timer2 setup ADuC7039 */ T2CON = 0; // Disable watchdog timer /* Timer0 setup ADuC7039 */ T0CON = 0x002A; // clock = SysClock/16384=625Hz, Count down, Periodic T0LD = 625; // 625Hz/625 = 1Hz /* GPIO setup ADuC7039 */ GPCON = 0x00001111; // all GPIO configured as SPI GPSET = 0x00000000; // GPSET=0 does not affect GPIO output level GPCLR = 0x00000000; // GPCLR=0 does not affect GPIO output level GPDAT = 0x34000000; //GPIO_2(MISO)/4/5 set as output, write 1; SPICON = 0x0109; //0809 /* ADC setup ADuC7036/39 */ ADC0CON = 0x8001; // enable I-ADC, twos complement, gain=2 ADC1CON = 0x8200; // enable V-ADC & T-ADC, select V-ADC, ADCFLT = 0x0007; // AF=0,SF=7,F_ADC=512KHz/(SF+1)/64=1KHz ADCMSKI = 0x07; // enable all ADC interrupt ADCMDE = 0x01; // ADC normal mode, continuous conversion /* ADC setup ADuC7032 */ // ADC0CON = 0x8001; // enable I-ADC, twos complement, gain=2 // ADC1CON = 0x8200; // enable V-ADC, unipolar coding // ADC2CON = 0x8200; // enable T-ADC, unipolar coding, internal Temp sensor // ADCFLT = 0x0007; // AF=0,SF=7,F_ADC=512KHz/(SF+1)/64=1KHz // ADCMSKI = 0x07; // enable all ADC interrupt // ADCMDE = 0x01; // ADC normal mode, continuous conversion /* IRQ/FIR setup */ IRQ = Vector_IRQ; FIQ = Vector_FIQ; IRQEN = 0x00000200;// SPI inti 0x4: Enable Timer0 int 0x00000004 FIQEN = 0x00000100; // ADuC7039 only: Enable ADC int |
1个回答
现在主机发送数据,中断一直有,就是没有数据,SPIRX接收的数据全是0,其他没有什么地方有问题了
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16901 浏览 31 评论
/9
GMT+8, 2025-12-2 04:03 , Processed in 0.572121 second(s), Total 71, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3426
