当我通过频率为5 Hz至1.0 MHz的600欧姆馈通测量连接到3458A的600欧姆音频源输出时,DVM读数开始以130kHz和1.0MHz滚降,DVM显示器> -6%。
当我将Fluke 5700A宽带输出连接到DVM时,5 Hz到1.0 MHz的偏差为 以上来自于谷歌翻译 以下为原文 When I measured a 600 ohm audio source output connected to the 3458A through a 600 ohm feed-through at frequencies 5 Hz to 1.0 MHz, the DVM reading started to rolloff at 130kHz and at 1.0MHz the DVM display was >-6%. When I connected the Fluke 5700A wideband output to the DVM, the deviation over the 5 Hz to 1.0 MHz was <1.0%. When I connected the terminated 600 ohm audio source to a HP 400F, the analog meter deviated <1% over the 5 Hz to 1.0 MHz. What's happening with the 3458A? Is this a software issue? |
1个回答
我只是试图验证HP 204C的正弦波输出电平是否在600欧姆终端(20Hz到1.2MHz)内达到最小2.5Vrms。
HP 400F表明输出电压> 2.5V。 使用Ballantine Labs型号1395A-3 M600,3V / 600ohm热转换器验证平坦度是否在1kHz参考值的1%范围内。 我还尝试使用3458A测量HP652A端接600欧姆输出,并得到了同样糟糕的结果。 谢谢 以上来自于谷歌翻译 以下为原文 I was just trying to verify that the sinewave output level for an HP 204C met the minimum 2.5Vrms across a 600ohm termination, from 20Hz to 1.2MHz. The HP 400F indicated that the output was >2.5V. Used a Ballantine Labs model 1395A-3 M600, 3V/600ohm thermal converter to verify that the flatness was within 1% of 1kHz reference. I also tried to measure the HP652A terminated 600ohm output with the 3458A and got the same bad results. Thank You |
只有小组成员才能发言,加入小组>>
2130 浏览 1 评论
1907 浏览 1 评论
1758 浏览 5 评论
2633 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1598 浏览 4 评论
576浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
488浏览 0评论
2296浏览 0评论
1343浏览 0评论
GMT+8, 2024-6-26 08:25 , Processed in 1.187882 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
