电子发烧友论坛|
嗨,我是Zynq7000和嵌入式系统设计的新手。
目前,我正在启动一个需要在Xilinx Zynq7000上构建嵌入式系统的项目。 除了音频处理之外,我将使用蓝牙适配器与移动设备进行交互作为主要功能。 我想知道是否使用Linux或Android操作系统,同时考虑到蓝牙工作的难度。 我找不到使用蓝牙的示例应用程序,因此如果可能的话,我会感谢一些参考。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I'm new to the Zynq7000 and to embedded system design in general. Currently, I'm starting a project which requires building an embedded system on Xilinx Zynq7000. I'll be using a bluetooth dongle for interacting with a mobil device as a main feature in addition to audio processing. I'd like to have advice whether to use Linux or Android OS while considering the difficulty of getting bluetooth working. I couldn't find example applications that use bluetooth, thus I'd apprecieate some references if possible. Thank you. |
1个回答
它可能完全取决于您想要使用蓝牙做什么,但一般来说,如果您不需要任何特定于Android的功能,则可以更轻松地以您想要的方式设置Linux。
只要系统上存在所需的USB蓝牙内核模块,使加密狗工作就应该是相当简单的。 与设备交互将取决于设备是什么 - HID设备非常简单。 如果它有点奇怪,你可能需要编写自己的驱动程序。 在Linux中完成所有这些操作可能比在Android中更容易,并且一般Linux社区中肯定会有更多人可以帮助您。 以上来自于谷歌翻译 以下为原文 It might depend on exactly what you want to do with Bluetooth, but in general if you don't need any features specific to Android, it's easier to set Linux up any way you want it. As long as the required USB Bluetooth kernel modules are present on the system, it should be fairly trivial to get the dongle working. Interacting with the device will depend on what the device is - HID devices are pretty straightforward. If it's something strange you might need to write your own driver. It will probably be easier to do all of this in Linux than in Android, and there will certainly be more people in the general Linux community who can help you. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 13:51 , Processed in 0.775436 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
26182
