电子发烧友论坛|
您好,我对Bootloader和TCPIP栈的系统服务/命令使用有一些问题。我的观点:MPLAB X IDE V3.61XC32 V1.43ValueV2.3BICD3PIC32嵌入式连接(EC)启动套件与PIC32 MZ2048 ECH144i要结合TCPIpU-UppServer demo(和谐 V2Y03BAppTCPIP)和BASIC demo(和谐 v2y03bAppsBootloader)。我的未来目标是通过UDP和BuototoDER使程序与TCPIpU-UppServer演示相类似,并通过USB设置控制台(以及其他一些东西,通过在内部检查SD闪存设备后,通过UDP发送复位和引导加载命令)。我的问题是:系统服务中的命令设置。这个设置似乎是必要的,以便使用控制台函数在TCPIpU.UppServer项目中用于控制台。当我启用这个设置时,每次我想编写我的板,MPLAB在ICD窗口中得到一个错误:DeVICEI编程失败已经有关于内存分配的问题。在我的链接器文件(BTLY.MZ.LD)中,但是我通过分配给KSG00SudithMeM(Rx)(大约0x800)的内存的少量增加来解决这个问题。
以上来自于百度翻译 以下为原文 Hello, I have some issues with the System Services/Command use with bootloader and TCPIP stack. My spects : MPLAB X IDE V3.61 XC32 v1.43 HARMONY V2.3b ICD3 PIC32 Embedded Connectivity (EC) Starter Kit with PIC32MZ2048ECH144 I would like to combine tcpip_udp_server demo (harmonyv2_03bappstcpip) and basic demo (harmonyv2_03bappsbootloader). My future goal is to make program similar to tcpip_udp_server demo with a booltoader by UDP and a console setting by USB (and some other stuff as send a reset and bootload command by UDP after checking inside a SD flash memory device). I already succeeded to run both project on my board, separately. My problem is : the Command setting in System Services. This setting seems necessary in order to use the console functions used in tcpip_udp_server project for console. When I enable this setting, each times I would like to program my board, MPLAB gets an error in the ICD window : Failed to program device I had already have an issue about the memory allocation in my linker file (btl_mz.ld), but I solved this problem by a small increase of the memory allocated to kseg0_program_mem (rx) (about 0x800). I would like to get some suggestions of what I would have missed. Thanks Endinar |
1个回答
嗨,我想我发现了问题所在:在数据空间中。当我编程我的板时,错误发生在内存配置中,ICD窗口显示:我已经检查了KSG0引导闪存数据空间:0x9FC0 0000到0x9FC7 3FFFFATE,随着我分配给KSG00X程序的内存增加。MEM(RX),它不应该超过数据空间:0x9FC01000 +(0x2FF0+0x800)=0x9FC31700 i将查看0x1FC0FF4C。
以上来自于百度翻译 以下为原文 Hi, I think I found where the problem is : in the data space. When I program my board, the error occur during the memory configuration and the ICD window shows : The following memory area(s) will be programmed: boot config memory configuration memory Configuration memory Address: 0x1fc0ff4c Expected Value = 0x00002021, received value = 0x00002023 Failed to program device I already checked the KSEG0 boot flash data space: 0x9FC0 0000 to 0x9FC7 3FFF Even with my increase of the memory allocated to kseg0_program_mem (rx), it should not overstep the data space : 0x9fc01000 + (0x2FF00 + 0x800) = 0x9FC3 1700 I will look about the 0x1fc0ff4c. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 19:25 , Processed in 0.878198 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1106
