嗨,伙计们,我的PIC32 MZ1024EFE100有问题,我已经集成到PIC32 MX设计中。关于这件事我已经提出了一些线索。我运行它在120兆赫,它运行一个无控制器的液晶显示器通过DMA&PMP OK在60Hz。我似乎不能得到睡眠模式正常工作,我有SLPEN设置为1在OSCCon,我试着关闭一切,只是为了测试功耗时睡觉。我将最终启用更改通知中断为电源键或充电器插入线进入UP。当运行独立代码是12Ma!在PIC32 MX,我能够得到这一点到150 UA与RTCC仍然活跃和CN中断。我看不出哪里出了问题,但我认为它并没有进入睡眠模式。我需要睡眠消耗小于1MA理想的电池保存,因为它是一个电池操作的测量手持设备。有人能帮忙吗?是否有任何睡眠/闲置消费数字为他们的MZ设计?任何轶事证据都很好,所以我知道我的目标是什么。
以上来自于百度翻译 以下为原文 Hi guys, I'm having trouble with my PIC32MZ1024EFE100 that I have integrated into an PIC32MX design. I've made a few threads about this. I'm running it at 120 MHz and it runs a controllerless LCD via DMA & PMP ok at ~60Hz. I can't seem to get sleep mode working properly, I have SLPEN set to 1 in OSCCON and I try and shut everything down just to test power consumption when sleeping. I will eventually enable the change notification interrupts for either the power key or charger inserted lines into the uP. Consumption when running standalone code is 12mA! On the pic32mx I was able to get this down to 150uA with the RTCC still active and CN interrupt. I can't see where I'm going wrong but I think it isn't properly going into sleep mode. I need sleep consumption to be less than 1mA ideally for battery preservation as it is a battery operated measuring handheld device. Can anyone help? Does anyone have any sleep/idle consumption figures for their MZ design? Any anecdotal evidence appreciated so I know what I can aim for. Thanks in advance |
3个回答
在勘误表中,你似乎无法关闭Flash(FEDCOFIT位在DEVCFG0),所以我想知道闪光灯是否仍在供电,这有助于我的高消耗。我也有BCFGIR标志设置在RCON寄存器中,所以我正在调查。这个线程是有用的:HTTP//www. McCHIP.COM/FUMMS/M89197.ASPXNO有一个关于PIC32 MZ-EF部分的睡眠/空闲消耗的数据?还是有类似的问题?谢谢
以上来自于百度翻译 以下为原文 In the errata it seems that you can't power down the Flash (FSLEEP bit in DEVCFG0) so I wonder if the Flash still being powered is contributing to my high consumption. I also have the BCFGERR flag being set in the RCON register so I'm investigating that. This thread has been useful: http://www.microchip.com/forums/m891997.aspx No one have any data on sleep/idle consumption for a PIC32MZ EF part? Or had similar issues? Thanks |
我有完全相同的问题(疯狂的电流绘制,而在睡眠模式)。我也在寻找答案。在这个线程中有更多的细节:HTTP://www. McCHIP.COM/FUMMS/M91184.ASPX
以上来自于百度翻译 以下为原文 I have exactly the same problem (crazy current draw while in sleep mode). I too am looking for answers. More details in this thread: http://www.microchip.com/forums/m991184.aspx |
感谢RISC成员指出了这一点。在数据表,第616页表33-8。如果你只得到12Ma,就要心存感激。情况并没有那么糟。也不好。
以上来自于百度翻译 以下为原文 Thanks to member RISC for pointing it out. Take a gander at the datasheet, page 616 table 37-8. If you are only getting 12ma, be grateful. It's not as bad as it could be. Not as good either. |
只有小组成员才能发言,加入小组>>
5212 浏览 9 评论
2019 浏览 8 评论
1944 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3192 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2246 浏览 5 评论
760浏览 1评论
647浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
567浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
659浏览 0评论
557浏览 0评论
GMT+8, 2024-12-12 12:46 , Processed in 1.327541 second(s), Total 80, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
