电子发烧友论坛|
你好,
我只是想知道哪个版本的XILINX ISE支持XQ4013E,因为我无法在xilinx ISE的新版本中找到它。如此,请提供xilinx版本的链接。请帮助我。 以上来自于谷歌翻译 以下为原文 hello, i just wanted to know which version of XILINX ISE supported the XQ4013E as i couldnt find it in the newer versions of xilinx ISE.If so please provide me the link for the xilinx version also.please help me. |
4个回答
嗨,
ISE 4.1i支持4000系列设备。 您可以从链接-http://www.xilinx.com/webpack/classics/spartan_4k/index.htm下载它。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, The ISE 4.1i had the support for the 4000 series devices. You can download it from the link - http://www.xilinx.com/webpack/classics/spartan_4k/index.htm. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.View solution in original post |
嗨,
ISE 4.1i支持4000系列设备。 您可以从链接-http://www.xilinx.com/webpack/classics/spartan_4k/index.htm下载它。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, The ISE 4.1i had the support for the 4000 series devices. You can download it from the link - http://www.xilinx.com/webpack/classics/spartan_4k/index.htm. Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
嗨,
所有其他旧版本的ISE也可以从链接中找到-http://www.xilinx.com/webpack/classics/wpclassic/index.htm 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, All other older versions of ISE can also be found from the link -http://www.xilinx.com/webpack/classics/wpclassic/index.htm Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 10:59 , Processed in 0.889918 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3041
