电子发烧友论坛|
嗨,
我正在尝试使用ST电机控制工作台接口通过由STM3240g-eval控制的STEVAL-IHM25V1来驱动PMSM。我不知道发生了什么,但是当我连接接口时,它表明同时存在两个故障:欠压和过流。通信工作正常,因为它显示了确切的总线电压值,并且高于项目中选择的最小电压,这是我无法理解的。所以,因为它我不能开车做马达。有人知道如何解决它吗? 我期待着一些帮助。 非常感谢你。 #motor-control-workbench#steval-ihm025v1#stm3240g 以上来自于谷歌翻译 以下为原文 Hi, I am trying to Drive a PMSM using the ST Motor Control Workbench interface through a STEVAL-IHM25V1 that is controlled by STM3240g-eval. I do not know what is happening, but when I connect the interface it shows that there is two faults at the same time: Under voltage and Over current. The communication is working well because it shows the exact Bus voltage value, and it is above the minimum voltage chosen in the project, that is what I can not understand. So, because of it I can't drive do motor. Does anybody know how to fix it? I am looking forward for some help. Thank you very much. #motor-control-workbench #steval-ihm025v1 #stm3240g |
2个回答
Ciao Christian
如果在故障确认之后错误仍然存在,则这意味着微观仍然看到这些错误。 您没有提到的一个修改是关闭SB16以将紧急输入连接到PI6(可能您还必须卸载默认连接到该引脚的相机模块) 之后,您可以验证PI6上的电压是否上拉至3.3V,这将清除过流错误。 (故障确认后) Regardind的undervolatge,似乎很奇怪。 设置到WB的阈值是125V。使用WB的“监视器”功能,您可以验证测量的总线电压(您还可以使用万用表验证测量的总线电压是否与实际总线电压一致)然后如果此值高于125V则欠压错误将消失。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Christian If the error remains after the fault ack this mean that the micro sees these error still in place. One modification that you don't mention is to close SB16 to connect the emergency input to PI6 (and probably you have to unmount also the camera modue that is for default connected to that pin) After that you can verify if the voltage level on the PI6 is pullup to 3.3V and this will clear the overcurrent error. (after the Fault Ack) Regardind the undervolatge, it seems very strange. The threshold set into the WB is 125V. Using the ''monitor'' feature of WB you can verify the measured bus voltage (you can also verify if the measured bus voltage is coherent with the real bus voltage using a multimeter) then if this value is above the 125V the Under Voltage error shall disappear. Ciao Gigi |
嗨,
谢谢,你是对的,我忘了关闭SB16。 问候 以上来自于谷歌翻译 以下为原文 Hi, Thank you, you were right, I forgot to close SB16. regards |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 07:06 , Processed in 0.610760 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7887
